Question about Kyocera Mita FS-1920 Laser Printer
I have a problem with kyocera fs9100
I can´t access to the printer by the network i tried to conect with a personal computer but i can´t ... the panel control is blocked ....i´d like to know how to unblock the panel control repair the printer..
  • 3 Answers
As for blocked, are you saying that the buttons wont acess the screen or is the display messed up. If it is locked it can be unlocked. Can you print out anything from it? Let me know, we work on the FS printers all the time. Russ
Posted on Jan 29, 2008
  • 417 Answers
Is there any error messages on the control panel? It is very easy to access the control panel all you have to do is press menu the the up and down arrows to wherever you need to go. The only this that may work is to remove the network card (Of which I'm sure this model has a removable one) then try accessing the control again.
(Be sure that the machine is off when you remove the network card)
If this works then the chances are that you have a faulty network card.
Hope this is of some help
Posted on Dec 27, 2007
Hi, how to whrite a command to set my printer that is not connected to any network and i only have an USB calbe.thank you
before you connect anything to a computer with an USB cable, you have to install the software that came with the device. No software, no working device. That is all. When you lost the CD, you could try on the support page from Kyocera, if they can help you with the correct software and drivers.
Feb 16, 2015 | Kyocera Ecosys FS-2100D Laser Printer -...
I have a kyocera mita fs 1020d. i tried to conect thru a network, but a dhcp is off. ii want to reset that values or to put in on position. help me sorry for my english, i`m romanian.
You need to use the Kyocera Mita Admin Manager Quick Set up Utility, it can be downloaded from the Kyocera Mita US wbsite using the following link.
Download the utility and the wizard will run you through making the changes.
You can also go to and pick another country / region to download from.
I hope this is helpful,
Mar 10, 2011 | Kyocera Mita FS-1020D Laser Printer
Kyocera FS-1028MFP has been set to SMB network authentication and will not allow login to html or panel. Need to reset printer back to factory to access and reconfigure.
You may contact Kyocera Technical Support Monday - Friday 9 am - 6 pm EST at:
1-800-255-6482, they should be able to assist you with this and there is no charge for the call or thier help.....totally free.
Jan 05, 2011 | Kyocera Office Equipment & Supplies
Cannot access Advanced page via browser on KyoceraMita FS-1118MFP
THE page might have been removed from there permanently from the database of google.
try that again ,u can have.
Apr 01, 2010 | Kyocera Mita Kyocera-Mita - NETWORK BOARD...
Network printing problem
A couple of possibilities you can try:
1. Use the installer CD on the other 2 PCs as well. When prompted, instruct installer that the printer is on a network; and/or
2. Use the parallel connection instead of the USB (or the other way around); and/or
3. Un-check the auto turn-off of USB devices in the Power Management tab of the USB Root Hub Properties.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 18, 2008 | Kyocera Mita FS 1010 Laser Printer
Conecting a laptop to a c250
if you connect directly, then you have to use crossover cable. or if you just want to print, use USB cable.
Apr 23, 2008 | Konica Minolta bizhub C250 All-In-One...
Printer printek web password
you can access this networked printer by their IP address
just connect through printer's IP address and you will get your printer access...
Mar 27, 2008 | Office Equipment & Supplies
Kyocera Mita FS-1920 Laser Printer Logo
155 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
