Question about Alpine CDA-9851 CD Player
Inop we are getting power to the radio but there is nothing on the face plate and no sound from spkrs
  • alpineblues Dec 30, 2007
    Same as above. In fact, the radio drains the battery but does not power up.
Yeah same problem, with a pioneer unit and also a JVC unit.
I think the problem lies in the 6 disk cd changer setup, something is little wonky there, just cant figuare out what, hopeing somone who resolved it could give us a hand
Posted on Jan 12, 2008
Radio works but face plate shows nothing
You have two possibilities. You can try cleaning the contacts on the back of the radio and on the subpanel with qtips and rubbing alcohol or a pencil eraser. If that doesn't work, you may have bad solder connections on some surface mount resistors inside of the radio. If you are good at soldering they should be on the right front of the radio, you will have to remove the cd mechanism to get to them.
Mar 14, 2012 | Kenwood KDC-MP4028 CD Player
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
Bought a cobra lx le from sparkys cb shack. using the radio as a base station. with the radio turned off , when i turn the power supply on a pyramid ps-7kx the radio face plate lights up for a couple of...
This is normal for the LXLE's. The new circuitry power the new face plate uses a small high voltage transformer and if power is applied to the receptacle on the radio it is drawing some current. When the power supply is turned off or on with the on/off switch on the LXLE turned off there is still a spike of current going through the radio. Not to worry, it will hurt nothing. If this is truly a problem, someone could probably design a little diode circuit to stop this issue. I would if I could but am not that smart.
Dec 21, 2010 | Cobra 29 LTD CB Radio
XHD6430 radio not fully powering on.
I had this same problem with this same deck, in addition to my sound going out for periods at a time. I solved the red light no-nothing else going on issue by pressing and holding the reset button for 5-10 seconds (on the unit, bottom left side - have to remove the removable face piece). Kind of frustrating still though, because every time I do that, I have to reset all my presets again. I had good luck with this deck in the begining, and now not so much. Customer Service from DualAV/Namsung is terrible - I don't think I would buy another deck from their company.
May 17, 2010 | Dual Car Audio & Video
I have an 03 suburban that I'm trying to wire a jvc radio however there is no sound coming from the speakers it seems as if they are not grounded even though I hooked them up according to the harness I...
I am sorry to have to tell you this but it is almost a certainty that the radio has blown outputs.These radios are very sensitve to reverse polarity and other miswiring issues. If power was applied to the wrong wire for just a second you can smoke the radio.You can try pop testing your spkrs., to see if they are good, get a small, or cheap ohmeter or continuity tester, disconnect each spkr and put the ohmeter (set at ohms, Rx 1) leads , one lead on each spkr. terminal and you should hear a little pop or scratch. If you do ,that spkr is good. If spkrs all good and have pwr to radio, probably have blown radio.
Mar 30, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
1998 beetle radio buttons
The face plate buttons actually activate small buttons on a printed circuit board behind the face plate. When I removed the radio and then the face plate many small pieces of plastic fell from behind the face plate. These small plastic pieces align the face plate button to the printed circuit board buttons. My Beeetle is almost 10 1/2 years old so I imagine the plastic is just becoming brittle with age. I could not set the radio to FM, so I removed the face plate button and now slide a toothpick in the slot to toggle between FM1 & FM2. Not he best solution, but probably the most inexpensive one. I also made my on tool to remove the radio from a diagram found at:
Jul 02, 2008 | 1998 Volkswagen Beetle
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
Kenwood KDC-MP333 in-car head unit
one or more spkrs are shorted. disconnect all spkrs and test one at a time with test spkr
Nov 10, 2007 | Kenwood KDC-MP228 CD Player
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Alpine CDA-9851 CD Player Logo
37 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
