Question about Zebra LP 2844 Thermal Printer
1 inch of left margin left even on the self test
Printer does not print on left area, leaving 1 inch of margin on all printings and pirnter self test
  • Anonymous May 15, 2008
Try using the "manual" width calibration. With the printer on, press and hold the green button. It will flash once, then twice, e.g. the sequence:
after the 5th flash, let go of the button. The printer will begin drawing rectangles which get wider and wider. Press the green button once (don't hold it) to indicate "when" the width is appropriate. However, I found the width was best calibrated when I let the printer draw rectangles right until the edge (where it automatically stops).
Posted on Jul 08, 2008
Why doesn't it print on LABELS at the top of the page?
I share a link please visit and follow step by step instruction.
I hope solved your issues.
http://ulearnoffice.com/word/printing.htm
Thanks,
HP Printer Support
May 30, 2014 | HP LaserJet 1020 Printer
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Hp6310 officejet all in one
here is solution..
Solution Step one: Make sure that the product prints correctly
  1. Print a self-test page from the product control panel, from Windows, or from the product software. (See the product user guide, available online, for instructions to print a self-test page.)
  2. Check to make sure that black and all colors (if using a color product) print on the self-test page.
    • If the self-test page does not print correctly, an issue might exist with the product hardware. See the product user guide, available online, for further troubleshooting steps.
    • If the self-test page prints correctly, continue with the next step.
Step two: Determine what portion of the page is set to print Many Web pages use frames. Frames divide the screen into multiple windows. Follow these steps to determine what portion of the page is set to print.
  1. Click the Internet Explorer icon on the desktop. The Internet Explorer window opens.
  2. On the File menu, click Print . The Print dialog box opens.
  3. Click the Options tab to view the print settings.
  4. Change the settings if required, and then click Print .
Step three: Change the Encoding setting in the Web browser
  2. On the Menu bar, click View .
  3. Click Encoding to view a list of encoding options.
  4. Check the Encoding settings.
    • If Auto Select has a check mark next to it, click to clear the check box.
    • If Western European Windows does not have a check mark next to it, select it.
Try printing again. If the issue continues, proceed to the next step. Step four: Check the page setup settings for the Web browser Web pages are designed to be viewed at a certain screen resolution. If the resolution of the screen is lower than the resolution of the Web page, the whole screen might not display or might not be printed.
  1. Make sure that Internet Explorer is open.
  2. On the File menu, click Page Setup . The Page Setup dialog box opens.
  3. Review the Margins information.
  4. Make sure that the margin settings are greater than or equal to the minimum printable region margins for the product. The margins vary slightly among HP All-in-One products. As a general rule, the settings should be at least the values shown in the following table. Side Margin Top Margin Bottom Margin 6.3 mm (0.25 inch) 6.3 mm (0.25 inch) 6.3 mm (0.25 inch)
  5. Make necessary changes to the margin settings.
  6. Click OK to save the changes.
Try printing again. If the issue continues, proceed to the next step. Step five: Print using Smart Web printing software HP Smart Web Printing is fast, free, downloadable software that enhances how Microsoft Internet Explorer and Mozilla Firefox print Web pages. Use HP Smart Web Printing for the following tasks:
  • Select text and graphics from any Web site
  • Save paper by combining portions of numerous Web pages
  • Preview and modify clips before printing
Thank you.......
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Zebra LP 2844 Thermal Printer Logo
1,169 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
