Question about Abit AB9 Pro Motherboard
AB9 Pro motherboard
I am building a computer and have everything in brand new power supply and when I go to turn it on nothing happens. The fan doesn't even run on the power supply. Jumper configurations are all correct. Any advice?
  • 143 Answers
Do this test this will tell you if your power supply is good or bad we will do the process of elimination ok.
How do I test if the power supply is bad?
Warning This test is for those with extensive electronics training. Do not try this if you do not have extensive electronics training. Make sure there is enough load connected to the power supply before testing ( at least motherboard and one hard drive)!
ATX power connector layout isshown above. 5VSB constantly provides 5V power to the connector through pin 9. If you have a voltmeter, while the power supply fan does not turn on, you could identify which pin is pin 9. Normally there is a clip on the connector between pin 15 and 16. If one can identify pin 14 (the only green wire goes to pin 14), this is the power-on pin. Onee can use a piece of wire to short pin 14 and 15 (or any other black wired ground pin). If you power supply has power connected to it and power switch on the power supply is on, the fan should be turning by now. Otherwise, your power supply may have problem.
Posted on Dec 27, 2007
    Scholar:
  • 152 Answers
Well.. if anything didnt spark and smelled burned.. you can still connect it up correctly.. or is the socket from t he wall that is not working...
does any led turns on? or does it beep when you try to turn it on? because that must mean its not getting any electricity
    Guru:
  • 1,894 Answers
Does the FAN in SMPS run? if the FAN in SMPS runs see if FAn in mother board runs
  • 1 more comment
  • dewan nafees ahmed Dec 27, 2007
    the 1st phase where poer enter the system is the SMPS. that is located along with the cabinet.
    1st chech if SMPS is reciving power by seeing if SMPS fan is spinning. it can be seen visibly from outside.
    if this is not occuring. try different socket or try different wires
  • dewan nafees ahmed Dec 28, 2007
    and one more thing to be noted....
    if SMPS fan itself is not rotating means there is no supply from your UPS. try connecting the SMPS to direct power and test if it is working. so that you can isolate the problem that you are facing.
    if SMPS is supplying power its it can be checked as follows.
    there will be four wires for each power output.
    red to black must give out 5 v... tis s meant for data i think
    yellow to black 12 v.. ths s meant for operation of device i think.
    you can test it using a multimeter...
    but this test is necessary only when SMPS fan is not running.
No power to my desktop computer HP A1330N and no green light in the back of the power supply
You replaced power supply and your made sure you plugged everything back into the motherboard snuggly and in it's proper place? If so it might be your motherboard is bad.
Make sure you have the new power supply turned on. Sometimes there's a O/I switch on the back of the power supply. Flip it and try to boot and see what happens. You might have another bad power supply.
If so your motherboard might be burning them out.
Try removing the power cord for 30 seconds and press and hold the power button. After 30 seconds put the power cord back in and press the power button to see what happens.
Do your fans work when you press the power button? Do you hear any fans running?
Mar 23, 2012 | Computers & Internet
Not powering on at all - I have been built a new computer from scratch with all brand new components. After hooking all of them up and plugging in the power source. Nothing is happening when the power...
1. Could be as simple as not having the Power Switch on the right jumper...double check.
2. The board will power up with nothing hooked to it... just power, CPU, MEM... disconect everything to just to get the board up to the bios.
3. Make sure PS is securly connected to the MB.
4. Check Jumper on the Board to make sure the Test Jumpers are not set
5. Memory is seated correctly... if you pull them out the board will start and beep...
Dec 31, 2009 | Gigabyte GA-G41M-ES2L Motherboard
Not powering on, but active power supply
1. Make sure you have all of the power connectors connected. There may be an additional 4-pin P4 connector and another on your video card.
2. Make sure CPU, RAM and cards are all well seated.
3. Frequently failing power supplies deliver less power before they die completely. It may just have enough power to spin the fan. Try another power supply. They are cheaper than a new MB and you can return it if it doesn't fix the problem.
I hope this helps.
Jul 17, 2009 | Abit AB9 Pro Motherboard
ABIT AB9 PRO WILL NOT POWER UP
Sounds like it's going to die or its gone faulty,
Might need to replace it or take it to a computer store and have them check it out.
Dec 28, 2008 | Abit AB9 Pro Motherboard
C1 code, computer won't boot
get the battery out of the socket and reset CMOS by jumper after you unplung the pc's mai power supply
Oct 24, 2008 | Abit AB9 Pro Motherboard
ASRock K7VM4
Your list of suspects:
1. Processor is cold dead.
2. Power Supply has got a problem. Just powering a fan is not a guarantee that it is powering everything normaly. Try a different one as you test agai.
3. I suspect your MoBo is good, but try a different video card also with your new DDR.
4. Do you hear the HDD cranking or whining when you turn on the PC? Keep ear near HDD and listen. It it whine-starts, it's a fair sign.
5. Try a different monitor while you test these.
Let us know what you find in clear detail.
Mar 03, 2008 | Asrock K7VM4 Motherboard
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Mach speed motherboard problem
I had the same problem once. I took it to CompUSA to have them diagnose the problem, and they said I fried the motherboard or CPU. The fans turn on just because your power supply is on.
Jan 14, 2007 | Mach Speed P4M800 (890552603480)...
Abit AB9 Pro Motherboard Logo
141 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
