Panasonic PT-47WX53 47 in. Rear Projection HDTV Television
Problem for Panasonic PT-47WX53 47 in. Rear Projection HDTV Television
SD Tech you answered my panasonic tv with 3
By jaybirdwv on Oct 15, 2009
SD Tech you answered my panasonic tv with 3 blinks and said you could post the repair for changing the ic's. I'm not sure if you have posted yet, or I just don't know where to find the instructions. On the right hand side their appears to be a coil or power pack that a large Red wire plugs into the top and goes up to 4 large Red wires, and it also has one smaller red wire going to the front of the tv. I'm not sure how to unhook this to remove the board for repair. Thanks jaybirdwv
Comments:
Oct 15, 2009
- SD Tech Thank you for posting instructions. I guess I do not need to remove the big red wire from the coil on the right hand side. jaybirdwv
Oct 16, 2009
- Thanks SD Tech. I'll give it a try. jaybirdwv
Oct 28, 2009
- replaced ic's and one resistor,turned tv on and it stayed on for about 5 minutes and picture started to jump around and it shut of and again blinked 3 times. I replaced all resistors, and when I turned on tv this time it powered up and again shut down but now it blinks one time with about a 4 second pause between blinks.
Oct 28, 2009
- SD Tech I replaced both ic's and one resistor that looked bad. I turned tv on and it stayed on about 5 minutes and I went to the convergent set up and the crosses started bouncing and the tv went off and the lite starter blinking 3 times again. I then replaced all the resistor on the back in front of the rear ic. When I turned on the tv this time it stopped again and now it blinks one time with about 4 seconds in between blinks. I did not replace the 3 resistor in front of the forward ic.
Nov 02, 2009
- SD Tech I desodered both convergent chips and the tv will turn on and stay on. Have I damaged the chips, or do I need to resoder the chips or will I need to get two more new ones. jaybirdwv
Nov 09, 2009
- SD Tech I removed the convergence chips and installed two new ones. with the box on the table, when I turn on the TV no lights lite up and the TV again shuts down.
Clarification Request
Posted by SD Tech on Oct 15, 2009
no, lots of people try to remove the board--the hard way and easy to damage board---once you get the whole light box out it is much easier and safer to repair that way...usually takes me 10 minutes to get it out. SD TECH
see prior post---I just posted them there for you--you should get an email telling you there is a new comment--the instructions are there now.
Best Solution
posted on Oct 29, 2009
Very Helpful)
SD Tech
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 97%, 938 votes
OK, here is what I suggest you do----remove the light box from the set and unsolder all pins on both convergence chips----see if the set will turn on and light up---you can turn the set on with the remote--its receiver is at the top of the three black lens.
sd tech
Comments:
Nov 02, 2009
- if any of the resistors are bad---the one they are in front of is likely bad---if set comes on and stays on I usually (I have had this happen only a few times) just replace both chips again--where ever you bought them you should have a warranty------I know it is a pain to have to do again but for me I always have several of the chips in case this happens.
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" SD Tech I unsodered both ic's and tv turns on and stays on. Now what do I do. jaybirdwv " - jaybirdwv
Popular Solutions for Panasonic PT-47WX53 47 in.
Questions and Unsolved Problems for Panasonic PT-47WX53 47 in.
Do you recommend Panasonic PT-47WX53 47 in. Rear Projection HDTV Television?
Answer
Answer
Panasonic HDTV 2000 purchase. Lost picture and sound suddenly. Turned it on and it continued to... (More)
Answer
Panasonic PT-47WX53 53" projection TV TV shut down with 3 blinks.I replaced one resistor and... (More)
Answer
i need remote for old big screen tv. i need to ajust the mirrows.model #trpaa022cim
Answer
I need an upgrade for my Matsushita Wireless Manger. It will only run on XP computers and I need a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
