Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green box keeps popping up in upper right corner
Green box keeps flashing on and off for no apparent reason while playing dvd's. Box shows channel TV is set too to recieve cable signal and mono/stereo mode. can press display button on remote and turn it off but it pops right back up. Enough to drive you CRAZY!!!
  • rschmoll Nov 21, 2008
    I have the same problem while watching TV and not DVD. The tv is hooked up to cable. Should I change something on my cable inputs? I am just running the coaxial directly into the tv.
  • Anonymous Dec 24, 2008
    I have this exact same problem while watching regular TV. Every time the audio signal changes from mono/stereo the box pops up. The only difference is that my TV is a 46" and its a blue box that pops up. There is nothing in the menu I have been able to change to solve this.
    Problem Solver:
  • 17 Answers
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Posted on Dec 31, 2007
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 26 Answers
Just say it works say yes below
Posted on Jan 06, 2014
Someone apparently has been messing with the remote control. The TV seems to be stuck in a mode. When the power is turned on, the TV shows a blue flashing channel indication (9-2) in the upper left hand...
Hello and yes there is a easy way to solve this issue, on your Panasonic remote go to options or menu, in your memory list there should be a selection called either factory reset or default settings, choose it and hit OK, this will set your tv back to its original out of the box state.
Jun 24, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
I have a Sony Trinaton XBR about 6 years old. Works great. Have Comcast cable and they recently installed a new cable box. Now I get all cable channels on "Video 6 - DVD" rather than "Video 7 -Cable Box"....
I was awaiting your response in chat session but could not get any thing.
Please hook cable box in Video input-7 instead of Video input-6 in TV and select Video input-7 with remote on TV.
Regarding continues on-screen display of video-6, press Display button on TV remote once, on-screen display will disappear.
Thanks.
Jul 12, 2009 | Sony Televison & Video
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sharp LCD tv "Audio window" keeps popping up on the corner
Replacing the cable box may fix the problem. But, you're the 4th person to have this same problem with this SHARP TV MONO only audio.
Try system reset button on the back of the TV or the box.
Feb 17, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Display box keeps popping on and off on screen
Your display box continues to pop up because of the way your optimum box is connected to the back of your television. If you are connected with a coaxial cable from the box to the back of the tv, you will get that display box. The reason you are getting it because of the weak signal coming from your coaxial cable(which is the worst cable to use when connecting ANYTHING to ANY tv, especially a lcd tv). That cable is sending a fluctuating signal and your television is adjusting to that(hence the reason the display box comes up). Use composite cables(typical red, white, and yellow cables) to connect your box to your television and I guarantee your problem will be solved. Make sure you unplug that coaxial connection from your box to the television.
Dec 08, 2008 | Sharp Aquos LC-32D40U Television
The channel information/display won't stop popping up every few seconds.
What you all need to do is get away from a coax cable connection. If you have a cable box, or satellite box, take the coax cable off and use red, white, n yellow rca composite cables to connect your recievers to the tv. if you dont have a cable box, either get one, or get a converter box and use a tuner outside of the tuner within the unit. The tuners in those tv's are built to show you when you experience signal fluctation(which is normal with a coax cable) and thats why the box keeps popping up on its own. good louck to you all with this problem
Nov 02, 2008 | Sharp LC-32SB24U 32 in. LCD TV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
966 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
