Question about NEC APC Smart-UPS 1400 (050-01803-000) UPS System
All Led's keeps flashing in the battery charge bar graph after replacing batteries.
I had to replace my batteries in my APC 1400. After replacing the batteries all the LED'S on the right side battery charge/utility voltage bar graph keeps on flashing.
Any help will be appreciated.
Thanks very much.
Triniman
  • Stephen Price
    Stephen Price May 11, 2010
    Did you replace the battery with one of the same type, same manufacturer and model?
Just remove the battery again & dont put it back till 30 minutes then connect ur batter again.
Posted on May 28, 2008
27.5 volt charging voltage
No, that right. The batteries are wires in series so the voltage is 24v and they need a little high input than that to charge correctly.
Jul 25, 2012 | APC Back-UPS Pro 1400 UPS System
The battrey leds stay flashing i changed battries also the led still flashing
Automatic: The UPS performs a self-test automatically when turned on, and every
two weeks thereafter (by default). During the self-test, the UPS briefly operates the
connected equipment on battery.
Manual: Press and hold the button for a few seconds to initiate the self-test
REPLACE BATTERY LED ILLUMINATES
Replace Battery LED flashes and
short beep is emitted every two
seconds to indicate the battery is
disconnected.
Check that the battery connectors are fully engaged.
Weak battery. Allow the battery to recharge for 24 hours. Then, perform a self-test. If the
problem persists after recharging, replace the battery.
Failure of a battery self-test. The UPS emits short beeps for one minute and the Replace Battery LED
illuminates. The UPS repeats the alarm every five hours. Perform the self-test
procedure after the battery has charged for 24 hours to confirm the Replace
Battery condition. The alarm stops and the LED clears if the battery passes the
self-test.
Sep 09, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
How to extract batteries from an APC Smart UPS 1400
greg milton, Hi, Did you get the top cover off of the "1400" battery back-up? How old were the batteries in the unit? My APC 1250 has two 12v 18ah units inside. It's best to replace batteries every 3 to 5 years! 12fixlouie
Aug 20, 2010 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Dropped APC 750XL now when turned on the Load Bar Blinks...
As far as I am aware this means a general system error, but I'm not too sure, best to check before you ditch it, but I'm not sure if they can be reset anyway.
Aug 11, 2009 | APC SMART-UPS 750 VA 120V (SUA750XLX320)...
APC Smart-UPS 1000VA UPS System calibation problem
If battery charge indicator is flashing it should be UPS calibration issue, If all the LED indicator is light up in the front panel and UPS still can go online on battery mode you just need to replace the board on the front panel and the light will just back to normal state.
Apr 25, 2009 | APC Smart-UPS 1000VA UPS System
APC Smart UPS 1400
The sealed lead acid batteries in them have come down a lot in price now, see here for one on batterytrader, 12v 7ah sealed lead acid battery
Jan 13, 2009 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Apc 1400
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
The other possibility is the charging circuit may be faulty.
Jul 08, 2008 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
After powering on, all non-graph LEDs keep blinking
That meens that UPS dont have battery power for minimum time (2min). Unplug some devices so UPS load need to drop below 25% and lets UPS recharge battery
May 31, 2008 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Question about APC Smart-UPS 1400
This is the battery you need to replace http://www.batterywholesale.com/battery-store/proddetail.html?prodID=619
Ther are a few places to get one
Nov 03, 2007 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
NEC APC Smart-UPS 1400 (050-01803-000) UPS System Logo
2,541 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
