Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
ViewSonic N2750w 27 in Volume turns down by itself tv can be on for a couple of minutes then turns down completely try to turn the volume up with the remote. will turn back down
  • rrazo Dec 13, 2008
    I have a ViewSonic N2750w and I turned it on this afternoon and suddenly the volume started turning down by itself. I unplugged the TV for about 10 min, plugged it back, without any luck. It never did that before. If I try to access the TV menu or the setup menu, what ever option is selected it decreases the value to it's minimum like if the left arrow was being pressed. I'm leaving it unplugged the rest of the night and see if by the morning something happens. Also I've been having an issue turning it on or off with the remote... I have to do it at least a couple of times. If I try to turn it on, I see the light on for a few seconds and then it goes off. The same way if it's on and I try to turn it off, it stays off for a few seconds and then it turns itself on again. I have no clue what the problem could be.
  • Anonymous Mar 29, 2014
    Please, Problem with ViewSonic N2750W TV works for about 3-5 minutes.Then off picture, only sound. Tks
  • 286 Answers
Could be a problem with the down volume button on the tv. the board it's on ir its harness. Check them all. Make sure the volume buttons plastic actuator moves freely and is not stuck.
If these parts are all good, you have a problem on the main board. You may have to trace the control lines as far as you can and check any capacitors along the way. If you have an oscilliscope you can test the lines to see if the up volume is working correctly. If there is noise on it, you might find a bad capacitor if you can trace it back far enough. Schematic helps here.
Of course, make sure nothing is shining on the sensor window on the TV. You might want to scope that line as well (IR sensor line).
If none of that helps, get hold of Viewsonic and find your closest service provider. You can order a main board from them.
Of course, you could try just using the audio out jacks to an amplifier or a surround sound amplifer. Then you would use the remotecontrol for the surround sound system to control your volume.
Bet you were going to buy one anyway right?
Posted on Feb 14, 2008
The volume lowers itself all the way down to 0 and the zero continues to flash like it is still attempting to lower
You can't reset it you have a sound problem circuit that needs to be fixed by a qualified tach.
Nov 01, 2012 | ViewSonic N2750w 27 in. HD-Ready LCD...
The main meun locked
Is this a viewsonic? I am told, to unlock the menu, try holding the up and down channel buttons in together. If all buttons are locked, try holding the up and down volume buttons in together. The buttons are under the screen. I am not sure if you can do this while the unit is powered up or do this while powering up. Try first while unit is powered and running. Each of the two processes should set the lock if not locked and should also unlock if locked.
May 25, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Screen changes colors only
Hold the Vol+ Vol- buttons down and turn on the power switch in the back of the unit.
The screen should turn blue and some square in the middle of it.
The noisy square is actually the bios being reset.
Once the unit turns itself off, you can turn it back as usual.
Note: Some of these units require a 3 button reset.
In that case hold Vol+ Vol- and Menu at the same time while you turn the power switch on in the back of the set.
I hope it was helpful.
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Viewsonic N2750w flashing different colors on screen
did you get any answers? I have the same problem.
Jul 06, 2009 | Televison & Video
I can't find a way to turn off internal speakers when using external audio amp with N2750w.
just turn the tv down to minimum volume i don't think there is a way to turn them off
Jun 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Viewsonic power lock
On the tv itself hold down channel up button while holding that press and hold the menu button . this will un lock it
Dec 29, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
TV just turns itself off
does this happen at night or dark days when lights are on? if so you might be using CFL lights which interer with IR info to the set. it can cause other problems such as random cannel change or no remote responce.
Dec 16, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
866 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
