Error code 018 and 0e4
If you have the installation disc, uninstall the program from the Control Panel Add/Remove Programs. After uninstalling, reboot the PC. Re-install the program and select your region again.
Since you don't mention which application you are using, you might try the options selection and see if you can change the region. If not, the above re-install will give you the chance to select the region again.
