The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer.
It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen.
If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled.
To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer.
Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window.
Click the "Restore" button.
If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup.
If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings.
Wait while iTunes syncs with your iPod Touch and restores the device.
iTunes will prompt you when this process is complete.
or
A hard reset restores your iPod Touch to its original factory settings.
This is useful when your iPod Touch is disabled and won't turn on or off, but all your data is erased.
Luckily, you can restore your data with iTunes after you've performed the reset.
Once you've performed the reset, your iPod is wiped clean and iTunes prompts you to restore the settings from your last sync.
Plug the iPod into your computer and wait at least 10 minutes.
This allows the battery to recharge in case it has drained.
This could fix your disabled iPod, if the problem was caused by a dead battery.
Click "OK" if your computer opens a "Connect to iTunes" alert box.
Depending on your version of iTunes, the message may indicate the iPod is in "recovery mode" and you need to restore the device.
ITunes opens and resets your iPod for you.
Unplug the iPod from your computer if you don't see the "Connect to iTunes" alert box.
Make sure the iPod is charged before you attempt the hard reset.
Press and hold both the On/Off/Wake button and the Home button on your iPod.
Keep the buttons pressed.
Wait for the Apple logo to appear, it may take 10 seconds or longer.
When you see it, release the On/Off/Wake button but keep the Home button pressed.
Release the Home button when you see a picture of a USB cable with an arrow pointing to the iTunes logo.
Plug your iPod back into the computer.
The iTunes "recovery mode" message will appear.
1. Reset or restore your iPod for a try, this can fix many general iPod problems.
2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library.
3. Update your iTunes to the latest version. Plug in your iPod. If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPod. I got this method from Apple technical support. Hope it helps. Contact me if you have any other question.
If you dont mind losing everything on the ipod -- connect to your computer and sync with your iTunes. This will replace everything on the ipod with the contents of your itunes.
If this is not what you want, you will need to google - removing songs from ipod this will give you various ways depending on your set up on how to get the tracks off your ipod without going through itunes.
A Mac or a PC with a USB 2.0 port and one of the following operating systems:
Mac OS X version 10.4.10 or later
Windows XP Home or Professional with Service Pack 2 or later, Windows Vista Home Premium, Business, Enterprise, or Ultimate edition.
iTunes 7.6 or later, available at www.apple.com/itunes
iTunes Store account (to purchase music over Wi-Fi)
An Internet connection
Before you can use any of the iPod touch features, you must use iTunes to set up iPod touch. You can also register iPod touch and create an iTunes Store account.
Download and install the latest version of iTunes from www.apple.com/itunes.
Connect iPod touch to a USB 2.0 port on your Mac or PC using the included cable. The USB port on most keyboards doesn’t provide enough power. Unless your keyboard has a high-powered USB 2.0 port, you must connect iPod touch to a USB 2.0 port on your computer
Follow the onscreen instructions in iTunes to set up iPod touch and sync your music, video, photos, and other content. Your computer must be connected to the Internet. By default, iTunes automatically syncs all songs and videos in your iTunes library to iPod touch. If you have more content in your library than will fit on iPod touch, iTunes alerts you that it can’t sync your content. You’ll need to use iTunes to select some of your songs, videos, and other content to sync.
When you get back to France, you'll need sync it with your PC. Download the latest version of iTunes then sync your iPod with your computer.
you can reset its password....but you'll lose all your data.Here's how...
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
You will want to reset the ipod and reconnect it to your computer. Below I have posted step by steps on three trouble shooting options. If after a reset it still will not connect to the computer, proceed to step two. Putting the iPod into recovery mode. Then if in recovery mode you can get it to connect to the computer, restore it to factory settings. Restoring it is listed as step three. I left the restore article normal in case you can get it to connect with just a simple reset.
1st reset
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
2nd RECOVERY MODE
Connect your USB cable to the computer without the iPod connected at the other end.
Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message: iTunes has detected an iPod in recovery mode. You must restore this iPod before it can be used with iTunes.
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPod and repeat steps 3-6.
Because you must restore the iPod touch, iTunes will not recover data from the device, but if it was previously synced on the same computer and the same user account, it should restore a backup (if available)
RESTORE
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update.
Connect your iPod touch to your computer.
Select your iPod touch when it appears in iTunes under Devices.
Select the Summary tab.
Select the Restore option.
When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
If none of this works and your iPod is still under a year old I would call apple. Make sure that you inform them of the trouble shooting you have already done though. They can tend to assume people don't do trouble shooting. GOOD LUCK
