Question about FireLite (USBFLB80) Hard Drive
Firelite Hard drive read as "local disk"
I have used two separate Firelite hard drives with my work and home computers for the past several years. One of the Firelites continues to work well. However, my computers began reading the other Firelite hard drive today as a "local disk" with no folders.
When I perform a search of all drives, the documents on my "bad" Firelite are listed. However, I cannot open any of these documents. Is there any way that I can recover these files? I have backed up the majority of the files, but don't want to lose my past 3 weeks' worth of work.
  • 5 more comments
  • harrier62 Dec 28, 2007
    Thanks for your recommendation. Unfortunately, the "bad" firelite still appears as a local disc (no folders). I did notice under Properties that the "bad" firelite (120 gb) only has a capacity of 37.2 gb. That's the capacity of my functional firelite (40 gb). Is it possible that the "bad" firelite got corrupted when connecting and disconnecting the two firelites?
    Thanks again for your recommendations. Unfortunately, I receive a "cannot find file" error message when I attempt to drag and drop my files into Rapidshare file uploading.
    I assume now that my recent files are gone for good. I also assume that they will definitely disappear if I reformat the Firelite.
    How do I format the Firelite for "once"?
    When I attempt to execute a "quick format," I receive a warning stating that "formatting will erase all data on this disk." Should I continue on?
    The link that you provided enables me to host my files with RapidShare. I'm confused about how to drag and drop any files if I lose all of my data due to formatting. I'm new to this, so please bear with me.
    Thanks again.
  • harrier62 Dec 29, 2007
    Thank you. I have just ordered a copy of the Recover My Files software. I should have it within 5-7 days. Will keep you posted on my progress.
  • tthomp Jan 26, 2008
    I have a similar problem. I have a firelite 80G USB and it is recognized on windows ME but not vista or XP No #@%$^ idea why it comes up as Local disc G on my computer page but on the devise manager it comes up as firelite not my laptop is down and it was the only one that would read the hard drive. Need Help
  • 1,006 Answers
1)Run CHKDSK ON that disc
2)Run antivirus to scan disc
Posted on Dec 28, 2007
  • 4 more comments
  • arben pllana
    arben pllana Dec 28, 2007
    Yess it is.I recomended you to format the hard driver and use this software to recover all you'r data.It is the only way i think
    Download
  • arben pllana
    no no just format HDD for ONCE and use this software to recover and all filess will be recover normally!
  • arben pllana
    Like in this PICS
  • arben pllana
    Or HERE
  • arben pllana
    Yess after formating all ur data will be lost but as i said just download that software and recover ur data!
    Good Night
  • arben pllana
    When u click download scroll down and go free or buy premium accaunt to download the program.
It runs but the light will not go on and computer does not regognize
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | SmartDisk FireLite 80 GB Hard Drive
Erase Firelite backups so drive is clean and I can start over
Empty the Recycle Bin -- the files that you "erased" were _only_ moved from their location into the Recycle Bin -- they still occupy just as much disk-space.
Jan 29, 2010 | SmartDisk FireLite 40 GB Hard Drive
USB Device Not Recognized...
try to the laptop firewire port, if works. I didnt find any support for youfirelite drive
Dec 29, 2009 | SmartDisk FireLite 40 GB Hard Drive
My verbatim usb160 worked the first four times I used it, but now my laptop is not reading the drive. It does work on my home computer. But if I can't transfer my data, what's the point?
There may be several causes for that.
If you say, that the drive reads OK on a desktop computer, but not on a laptop, then the drive itself is fine.
First, try to establish, whether the drive spins up correctly when attached to a laptop. Hard drives need a considerable amount of power to spin up (the first second or so), usually slightly above the 0.5 Amp limit that USB specifications require. Desktop computers, as they have a large power supply, can output this momentary extra current without problem, whereas laptops, where power is tightly controlled (to facilitate longer opearation on battery), may have the output power more strictly limited. Try all the available USB sockets on your laptop, sometimes one of them will be able to give just enough power.
If the drive spins up correctly, and you hear the familiar "USB device attached" sound, then the next step will be to check the Disk Management if the drive is seen by the system.
Assuming you have Windows XP or Vista, go to Administrative Tools and find Disk Management (you can also right-click the My Computer icon on desktop and choose Manage).
When you click Disk Management on the left, you will see on the right side the drives and volumes found on the computer. If you see, apart from your first hard disk (the one that contains the C: drive volume), another disk of the size similar to the size of your USB drive, we're good. You can right click the volume on this drive and choose "Assign drive letter", choosing a letter near the end of the alphabet, like "V" for Verbatim for example. Confirm the operation, and go to My Computer to see if the drive appeared as a V: drive.
Good luck, and don't forget to come back with a testimonial if helped :)
Nov 15, 2009 | Verbatim 160GB USB FireLite: The "drive...
How to backup your computer onto a firelite hard drive
VISTA: Hit the flag and go to computer. You should see the hard drive then if it is plugged in.
XP: Hit start and go to my computer and you should see the hard drive then if it is plugged in.
If this doesn't work try another USB slot for the dard drive. Some of your USB slots may be defective.
Oct 18, 2009 | FireLite (USBFLB80) Hard Drive
Backing up my IPod using FireLite
it has to know were it comming from can u copy paste your music to hard drive 1st then to firelite ok
Jan 29, 2008 | SmartDisk FireLite 60 GB Hard Drive
My mac computer do not reades or recognize my external hard drive 60GB smartdisk from firelite
well. Open Disk Utility in the Applications folder under Utilities and see if it shows up and possibly mount it from there. Also open the System Profilier (also in the utilities folder) and check under USB - if that's how it's connected.
Nov 12, 2007 | FireLite (USBFLB80) Hard Drive
Smartdisk firelite
please use a recovery program for mac and then once all files are recovered then repartion hdd in disk utility then copy back all files to hard drive or change your external drive as you are the fourth person to have this problem with firelite hard drive for the mac sounds like a compatabilly issue with mac os systems
Jun 01, 2007 | SmartDisk FireLite 40 GB Hard Drive
FireLite (USBFLB80) Hard Drive Logo
212 people viewed this question
Top FireLite Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a FireLite Computer and Internet Expert? Answer questions, earn points and help others
