Question about ViewSonic VX900 19" LCD Monitor
Help needed! My VX 900 Monitor was working when it went out and now gives black shielding. I tried to restart,, but the screen went black. As barring him from the network and again involving it it lightens and shows normal picture at moment, then again goes out. It even stopped to make that after few days. Please help out! What To do it? Is it on the bedding?
It's probably a problem with the backlight or the backlight inverter... i had the same problem just a little while ago. If your electrical components savvy, you might be able to find the problem on the inverter (which is on the side of the monitor once you get inside). Otherwise look into replacing the bulbs (which are on the top and bottom)
Posted on Feb 10, 2008
I have a Toshiba satellite the screen went black it is still running but sc4een black. Have tried many restart options need help
Depending on the model the screen may have failed, the inverter failed or the GPU failed. Plug an external monitor in, power up the laptop and if you get a picture, your screen failed. If no picture the Nvidea GPU has failed.
Dec 21, 2016 | Toshiba Computers & Internet
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
I have a dell e198fp monitor con nected to a dell latitude d400. Got monitor from daughter who said monitor was working then went black and stayed same. I get a blinking green power button with a black...
I suspect you will find that there are bad capacitors on the power supply board. If you aren't handy with a soldering iron, however, I would not recommend this repair. It can be easy to permanently damage things. If you aren't afraid of that, however, give it a try.
There are two that I have found that typically fail (680 microfarad, 16 volt). They usually "bulge" on top after failing. I have found that the replacement value doesn't seem to be too critical. I wish I had written down the actual designators for these caps (maybe next time I repair one of these monitors).
WARNING! DISCONNECT POWER BEFORE DISASSEMBLING THE MONITOR AND DO NOT RECONNECT POWER UNTIL ALL SHIELDING IS REINSTALLED!!! DANGEROUS LINE VOLTAGE WILL BE EXPOSED!!!
Once you get the bezel apart and get down to the metal shielding, slide the shield on the right hand side to remove (arrows pointing to each other). There will be four connectors underneath this shield to power the backlight. Disconnect these four connectors, paying close attention to where they were connected.
Disconnect the small ribbon cable on the other side connecting to the front panel controls...There is a small black tab that will flip up to allow removal of the ribbon cable. CAUTION! THESE CABLES ARE DELICATE...DAMAGING THE CABLE OR THE CONNECTOR WILL DESTROY YOUR MONITOR.
There are four screws holding the power supply section to the LCD itself (two on each side). Once you remove these screws the rear shield (and power supply section) will start to separate from the LCD. There is another ribbon cable between the power supply section and the LCD panel...AGAIN...DO NOT DAMAGE THIS CABLE OR CONNECTOR! Squeeze the two black tabs on either side of this connector to remove.
You should now have the power supply board exposed. Remove the screws securing the power supply board to the shield. You will need to disconnect the connector attaching the AC power inlet to the board in order to access the top side...
The failed capacitors should be readily apparent. Replace them, re-assemble and test.
That's it
Jul 25, 2011 | Dell E198FP LCD Monitor
My monitor was going zigzaging in different lines with my color back ground going with the linesand then went each time it came on then had to restart it to make screen go back to normal then went all...
When you first power on the computer does the monitor work fine?
can you boot into safe mode? - Click Here for step by step to boot into safe mode.
If the Monitor works in Safe mode or works when you first power on the computer then it could most likely be an issue with your Video Card.
Try testing the Monitor on the laptop to see if it gives you the same issue. If it doesn't then you know for sure it the Desktop. I would most likely say its the video card.
If it turns out to be the Desktop, post the model of the PC and I can help see what other options you have.
Apr 15, 2010 | Computers & Internet
I have been having trouble with the screen image moving to the right so that there is about a 2" bar of black in the left margin of the screen. I went to my control panel and adjusted the screen resolution...
you need to reboot into safe mode (hit F8 during boot up), then set the video to 640 x 480, then reboot into regular mode , then reset it again to the native resolution of this monitor, 1440 x 900 @60 Hz.
The monitor this old may also have capacitors problem, http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Post post back so it may also other people also..
Apr 08, 2010 | ViewSonic VA1912wb 19" LCD Monitor
PC Screen Went Black, Nothing Appears
try to restart holding down F8 this puts you in safe mode then erase program and use yourestore to earlier date
Apr 05, 2009 | HP w1907 LCD Monitor
Black screen
This is going to sound like a silly but my webcam has one on it. Does you web cam have a shield on it to prevent viewing?
May 27, 2008 | Microsoft LifeCam VX-3000 Web Camera
Hp laptop wont restart
please connect your laptop to external monitor.
if it works with external monitor, then the problem is with your laptop monitor driver.if that is the case, then re-install laptop monitor drivers.
if it doesn't work even with the external monitor, then re-install graphic card drivers.
Apr 05, 2008 | Computers & Internet
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
ViewSonic VX900 19" LCD Monitor Logo
52 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
