Panasonic tv I have blue lines in my picture starting from the left side to the right side
  • Anonymous Jan 09, 2008
    yes it's really noticable when the screen is dark.
    curved blue lines that go from left to right all the way down the screen.
You need your convergence ic,s replaced most likely stk392-110 depending on the model #.
Posted on Mar 31, 2008
2000 PANASONIC TV WITH RIGHT SIDE OF PICTURE THE GREEN AND RED COLORS ARE ABOUT A 1/4" OFF FROM EACH OTHER
trysetting the convergence on the tv itself,if that doesnt work you have a bad convergence amp maybe just 1 of them,you have 2 1 for greenand red 1 for green and blue,hope that helps.
Jan 17, 2013 | Panasonic Televison & Video
When i try to adjust the convergence, the red and blue adjust ok, i assume the green in the basline color, but it turns up on the right side of the screen and the picture has a green wave in the lower left...
The tv 100% have convergence problems,it dead,if have any colors lines mis alignment or don't stay in the convergence - + grid.The tv convergence board is dead.The 2 STK convergence ICS and some or all is resitors are dead.Must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Panasonic PT-47WX49 47" Rear Projection...
The Panasonic mod# pt-47wx49e has started to have a blue and a yellow shadow on the right side of the screen. the rest of the screen is normal. The operating instructions give you diddle to on. Do you have...
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows or 3D colors pictures.The tv convergencce board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 10, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
Apr 14, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Blue is just not right
Typical convergence problem. Your going to have to have the two convergence IC's replaced at one time but if you have no soldering skills or know about the safety facts with solid state TV repair, you really should call out a trained service person to assist this repair for you.
Oct 07, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
