Question about Kenmore 63942 Dryer
Runs but no heat
The dryer runs full cycle but there is no heat
  • 6 more comments
  • tluv84 Dec 30, 2007
    I'm not sure of which # my kenmore has, but the mdd # is 110.67732794 and it does run, but there it only blows cold air. It is an electric dryer, what could the problem be?
  • grandpad Jan 08, 2008
    Kenmore 110 728 12101 gas dryer is running throught the cycle but not heat. I have cleaned and checked all areas for lint cloggs and still have no heat.
  • Anonymous Jan 15, 2008
    dryer works but no heat? do i need a heating element?
  • iwilltry Jan 18, 2008
    Kenmore dryer model 73722694 serial No.0702383 no heat vent is clean where will the fuse be or should i check the heating element and where will is find it i have take the back of the dry off and i see pru gs that is connected is that the heating element. it have about 4 wire attach to it. HELP PLEASE before sears stick it to me thanks. (smile)
  • Anonymous Feb 07, 2008
    MY 2 YEAR OLD KENMORE ALSO HAS NO HEAT BUT WORKING
  • joni74 Aug 24, 2008
    my mother had just gotten a newly used dryer that was sitting in storage for some time first day it worked and now it works but no heat maybe the heating element , thermal fuse , or power feed , or breaker ? I dont want my step dad going out buying something and thats not the problem. its a kenmore ELITE front loader
  • bkalies Sep 03, 2008
    My Kenmore dryer 417.84052500 runs but constantly beeps and lately there is little or no heat. Please help, Sears won't even talk to me without paying $65 for technician. Help!
  • tburr9783 Sep 17, 2008
    Where do I find the fuses so that I may replace them. My manual claims this will fix the "runs but no heat" problem.
Check these items not that
Posted on Sep 04, 2008
I just resolved this problem on a Sears Kenmore 417-811 42000. The issue turned out to be in the power feeder block - item 52 in the diagram you can see at http://www3.sears.com/Paul/Leadimage.asp?productTypeID=0151200&brandID=0582&modelDesc=DRYER&modelNumber=41781142000&documentID=P0102216&documentTypeID=PLDM&documentClassCode=PM&titleType=DRUM&titleID=00001
This is a very easy fix - you just have to remove two retaining bolts to release the stress- reliever (11 in the diagram), the earth bridge to the chassis, and then release the three screws that hold the cables in position.
One of the positive feeds had come loose and had been shorting until eventually the cable melted. Earth and the other positive feed were fine. I replaced the entire cable with a slightly longer cable from Home Depot (10 gauge 30 amp 6ft Dryer Replacement cord 3 wire) for around $14. This cable comes supplied with a slighly different stress reliever from the original, but it works fine. Or you could use the original stress reliever if it is in good condition.
I found that the captive nut for one of the retaining screws has become corroded as a result of the arcing that caused the damage, so I replaced all of the captive nuts and screws (Home Depot parts 30699 85398 and 30699 68688) - this is simple if you carefully bend the retaining tab up with a pair of needle-nose pliers, drop the new nut in place and bend the tab back down.
Posted on Jan 13, 2008
  • 36 Answers
Check for power promblem 220 not getting to drier reset the breaker it will run on 110 but not heat fools people check out let and power cord at terminal block if cord is burned in two just means it was loose when installed no drier falt just replace cork terminal block or both
Posted on Dec 29, 2007
Dryer runs but will not heat
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 24, 2015 | LG DLG9588 Dryer
Dryer is spinning but not heating. we cleaned vents, unplugged dryer and replugged in. now it still won't heat and an hourglass symbol has appeared on control panel
Apr 11, 2015 | Samsung DV419AE Dryer
Beko drcs76b dryer not heating up, i have changed the heat element but still blowing cold air, any suggestions?
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Apr 03, 2015 | Dryers
My roper dryer starts runs few min. Then stops
Feb 17, 2015 | Roper Dryers
I have a Samsung dv220aew xaa dryer that does not produce heat. I've replaced the heating element, the thermistor, and the thermostats with the problem remaining, what could be the problem?
ARE U GETTING THE RIGHT AMOUNT OF VOLTAGE AT THE CONNECTION,? i VE SEEN IN SOME CASES WHERE THE MACHINE ONLY GETTING 120 AND WILL RUN BUT NOT CREATE MUCH HEAT? THE DRYER USES 120 TO RUN THE CYCLE BUT NEEDS A FULL 220 FOR THE HEAT CYCLE TO WORK, THUS IF UR MISSING VOLTAGE IT WILL NOT HEAT? ANOTHER CULPRIT COULD BE A BAD TIMER STUCK ON COOL DOWN OR FLUFF CYCLE AND WILL PRODUCE NO HEAT?
Sep 25, 2014 | Dryers
The dry wont run on high heat cycle but will run on the low heat cycle
Could be the Hi Limit Thermostat causing problems. There are over 350 Roper Dryers. Not much can be diagnosed without knowing the actual model number of your dryer. Please drop a comment with full model number. You can view the parts by selecting the correct model from this site.
RoperDryer Parts
Sep 02, 2014 | Roper Dryers
Whirlpool duet dryer won't heat up
Jul 02, 2014 | Whirlpool LAB2700ML Pedestal Drawer for...
Dryer running, but not heat
May 05, 2014 | Frigidaire Electric Dryer
Dryer tumbler for a short time then shuts off,will not run a full cycle like it stuck
see this causes and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the Heating Element.
Sep 27, 2012 | Amana ALG331RAW Gas Dryer
Dryer doesn't always run a full cycle or heat
the moisture sensor is probably bad
Oct 21, 2009 | Kenmore Dryers
Kenmore 63942 Dryer Logo
270 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
