Question about RCA OPAL M4001 MP3 Player
Help please When I plug my mp3 player to my computer through a highspeed hub the player says usb connected, but the computer is saying that the devices weren't installed b/c a service installation section in this INF is invalid
I find that pushing the reset button works usually, and does not lose data.
Posted on Aug 14, 2008
My rca opal want come on when i charge it
Posted on Dec 27, 2007
I have 4 USB 2.0 highspeed slots in Back of computer and 2 In front but when I connect a 2.0 highspeed Falshdrive or my HP Printer it gives me a message saying this device could work faster if it would be...
u need to update the usb hubs drivers without the current drivers the 2.0 port will function as a 1.1 port go to the device manager and update drivers for the usb root hub
Jan 18, 2011 | Sony Computers & Internet
My sony nwz e 436f says that I need to charge it but when I plug it into charge, it says Battery full.
I think you are using a USB-Hub. Connect the player directly to the computers USB port. See the manuel on page 100 (English version)
Nov 20, 2010 | Sony NWZ-E436F MP3 Player
Will not connect via USB hub
I am guessing that the usb hub is not powered. Most usb charing based mp3 players require a certain amount of power in order to be used on the computer or charged by it. I would recommend plugging it into a direct port or buying a powered usb hub.
Jan 14, 2010 | SanDisk Sansa e250 MP3 Player
My computer says the USB port connected to my mp3 is drawing too much power and has shut down the USB port. How do I get around this? I have a MacBook Pro.
It look that your player is drawing too much current from your Macbook Pro: it is rather unusual nowadays but does happen even with some USB external 2.5in drives!
Solutions:
1) Buy a USB Power Adapter Y cable that plugs into 2 usb ports on your Computer an thus allows double the current (shop around as they are expensive on Amazon but pretty cheap on Ebay)
2) Plug your player via a 'Powered' USB Hub that can provide higher current (from its 'own AC/DC power pack') to each USB port on the Hub
Hioe it helps!
Dec 28, 2009 | SanDisk Sansa Fuze MP3 Player
Walkman will not charge
Whenever I plug my Walkman into my USB hub, which is connected to my desktop, it too says it's battery is full after just a few seconds. I plugged it directly into my laptop, and it took a charge as normal. Then I plugged it into a different USB port on my desktop, and it again took a charge as normal.
So, if you are using a USB hub, try plugging the Walkman directly into one of the computers USB ports, you may have better luck.
Mar 26, 2009 | Sony NWZ-E438F Digital Media Player
Usb
I'd buy a USB 2.0 hub, connect it to one of the ports, then set the hub on top of the computer. That would make it convenient to connect devices to the hub and give you high speed to run your new devices. Good luck
Nov 12, 2008 | ASUS Ai Lifestyle M2N-E (ASKU49311)...
HUB power exceeded on MP3 Player
It sounds as if you have too many USB items plugged in at the same time.
When you connect a device to a computer via USB, the device draws its power from the computer. There is only so much power the computer can supply, and if you connect too many devices it can cause problems (hence the error message).
I would suggest that you disconnect any USB items that you are not actually using. If you are unable to do this, it might be necessary to by a USB hub with it's own external power supply.
Matt
Mar 02, 2008 | Audio Players & Recorders
Computer wont read mp3 player when connected
well i would invest in a hub carrier with it own power sorce 2.0 recomended this should solve your problem well i no it will just go to any com shop and ask for a 2.0 hub or internal usb ports but i must stress it needs to be 2.0 or moor
Feb 25, 2008 | Apple iPod shuffle MP3 Player
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
RCA OPAL M4001 MP3 Player Logo
70 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
