Question about SanDisk Sansa e250 MP3 Player
Refresh database just keep popping up on the screen. plus my computer won't read the device
  • pbk6 Dec 28, 2007
    My MP3 fails to execute likewise. It does not undertake what it claims. I'm very despairing about this complication and I do not wish to procure an additional MP3.
My MP3 does not undertake what it claims. I'm very despairing about this complication and do not desire to procure an additional MP3. Please renovate this quandary.
Appreciation, Mrs. Divenswaller
Posted on Dec 28, 2007
Stuck on fresh database
Some songs or files with extension device can't read, so it takes so long/infinity to refresh. Plug the device to pc, format it.
Good luck
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
Can't get past "Refresh Database" Screen
Hi
Try taking it back to the shop.
If not go to http://www.sansa.com/support
Tom
Jul 21, 2009 | SanDisk Sansa e260 MP3 Player
Refresh database
it's supposed to refresh database anytime you make changes to your clip. also, check in the settings what usb mode you're in as well as "my computer" to see if the device shows up when it's plugged in. as for transfering media, if you want to use a program to do it for you, use mtp (under settings on your clip). if you want to manually drag and drop, put it in msc (also in settings). also in msc, it doesn't really matter where you decide to drop the files onto the player, although there should already be a music folder to help keep things organized.
Jul 10, 2008 | SanDisk Sansa Clip MP3 Player
Refresh database?
Try this
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Jun 19, 2008 | SanDisk Sansa e260 MP3 Player
Refresh Database
Firmware upgrade needed most likely:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 06, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
MP3 not being recognized by computer
My opinion.
No one here seems to understand the question...unless it's just me.
Not being recognized by computer means you should not be able to disconnect the device safely. Am I right?
I cannot seem to disconnect the device safely, which means that the refresh database option will not display and do so!
Help?
Nov 06, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260
Try this;
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Nov 05, 2007 | SanDisk Sansa e260 MP3 Player
Frozen on refreshing database
-Tha Mp3 Doctor
Apr 18, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
48 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
