Radio Shack (43-3829) Digital Answering Machine Logo
Anonymous Posted on Oct 15, 2009
I have lost my paperwork and manual and do not recall how to place a new outgoing message, set time, etc.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
268
Points
I found an explanation on the site, Thanks.
Dect 6 Manual is lost. Where can I find one?
Step 1: Determine the make and model of your DECT 6.0 phone.
Step 2: Repost your question, being sure to include the information from Step 1.
Need help in setting time and answering machine.Dect2188 Can't see where to set time or how to set outgoing message on this new phone.
You may download a copy of the manual here. The day/time instructions are on pages 9-10. The outgoing message instructions are on page 21.
I am having problems setting up outlook 2007 for my yahoo.es address.what are the incoming and outgoing mail settings. when I try to do the auto set up it doesnt seem to recognise my network password for...
Here’s how you can read your Yahoo! Mail Plus email using Outlook 2007:
  1. From the Tools menu, select Account Settings.
    Note: If you do not see Account Settings, place your cursor over the two arrows at the bottom of the list to display more choices.
  2. On the E-mail tab, click New. The Add New E-mail Account dialog box appears.
  3. Select the Manually configure server settings or additional server types checkbox. Click Next. The Choose E-mail Service screen appears.
  4. Select Internet E-mail, and click Next. The Internet E-Mail Settings screen appears.
  5. Complete the fields as follows:
    • Your Name: Type your name as you’d like it to appear when you send an email message.
      E-Mail Address: Type your Yahoo! Mail Plus email address (for example, [email protected]).
      Account Type: Select POP3 from the pull-down menu.
      Incoming mail server: Type plus.pop.mail.yahoo.com.
      Outgoing mail server (SMTP): Type smtp.mail.yahoo.com.
    • Select the Remember Password checkbox if you don't want Outlook to prompt you for your password each time you check your mail.
    • Do not select the Require logon using Secure Password Authentication (SPA) checkbox.
  6. Click More Settings. The Internet E-mail Settings dialog box appears.
  7. Select the Outgoing Server tab:
    • Select the My outgoing server (SMTP) requires authentication checkbox.
    • Make sure that Use same settings as my incoming mail server is selected.
  8. Click the Advanced tab:
    • For Incoming Server (POP3), select the This server requires an encrypted connection (SSL) checkbox. The number in the Incoming Server (POP3) field automatically changes from 110 to 995. If it doesn’t, type 995.
    • In the Outgoing Server (SMTP) field, type 465. Under Outgoing Server (SMTP), select the This server requires an encrypted connection (SSL) checkbox.
    • Next to Use the following type of encrypted connection, select SSL from the pull-down menu.
    • If want to keep a copy of your email messages on the Yahoo! Mail server, select the Leave a copy of messages on the server checkbox. If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook, leave the box unchecked.
    • If you want to save your Yahoo! Mail messages on both the Yahoo! Mail server and on your computer, select the Leave a copy of messages on the server checkbox. If you want your messages to be deleted from the Yahoo! server after Outlook has downloaded them onto your computer, leave the box unchecked.
      Note: After your messages are deleted from the server, we cannot retrieve them.
  9. Click OK to close the Internet E-mail Settings dialog box.
  10. Click Next to continue. The Congratulations screen appears.
  11. Click Finish to close the Add New E-mail Account dialog box.
  12. Click Close to close the Account Settings dialog box.
Troubleshooting tips
If you still can’t send Yahoo! Mail from Outlook 2007, you might be accessing the Internet through an ISP that is blocking the SMTP port. If this is the case, try using port 587 when sending email via Yahoo!’s SMTP server. To make this change:
  1. From the Tools menu, select Account Settings. The Account Settings dialog box appears.
  2. Double-click your Yahoo! Mail Plus account. The Change E-mail Account dialog box appears.
  3. Click More Settings. The Internet E-mail Settings dialog box appears.
  4. Click the Advanced tab.
  5. In the Outgoing Server (SMTP) box, type 587.
  6. Click OK to close the Internet E-mail Settings dialog box.
  7. Click Next to continue. The Congratulations screen appears.
  8. Click Finish to close the Change E-mail Account dialog box.
  9. Click Close to close the Account Settings dialog box.
Feb 11, 2010 • Yahoo Mail
2answers
I wish to create my own message on the answer-phone.
The easiest way to gain access into an answering machine is to use it's preset access code. This is the access code set at default by the vendor on the given device. The best thing about this is that most users don't bother to change the access code to their device, if they even know that they have such a feature. Even worse yet, some of the manuals given for the device by it's vendor even tells the user that changing the access code is optional, not necessary. So of course since most people only do what they feel is necessary, these access codes are many times if not usually set at default. So what I'm going to do for you now is list the different popular vendors out there, and include their preset access codes, how to use them, and controls to use after gaining access. Keep in mind that if there is no model number beside the vendor, then that means that the information given works on most of their models. Likewise of course if there is a model identification beside the vendor name (placed in parenthesis) then that of course means that the information provided is model dependant. So let's begin, shall we?
1) AT&T - preset access code is 10 - when the answering machine picks up punch in the access code
7 - play messages
6 - play new messages
# - stop/pause
2 - repeat message
5 - skip message
4* - record announcement (push # to end recording)
41 - play announcement
* - record memo
33 - delete all messages
3 - delete selected
0 - turn system on
88 - turn system off
99 - change remote code
2) BellSouth - preset access code is 555, Mailbox 1: 555, 2: 666, 3: 777, 4: 888 - when the machine picks up hit * and then punch in the access code
0 - help (use this to get the commands available)
3) Freestyle - preset access code is 000 - when the machine picks up push in the D button and then punch in the access code
2 - play all messages
3 - play new messages
4 - skip back during messages
5 - delete during messages
6 - skip forward during messages
8 - play outgoing message
9 - record new outgoing message
0 - set answering machine on/off
1 - hear main menu
4) Vtech (VT650) - preset access code is 0000 - enter access code during announcement
#4 - repeat message
#5 - pause message
#6 - skip to next message
#7 - delete message
#8 - skip backwards
#9 - stop/exit any function
*8 - room monitor
5) Vtech (VT2650/VT2468) - preset access code is 50 - enter access code during announcement
#4 - repeat message
#6 - skips message
#5 - stops
#9 - delete message
#7 - review announcement (after beep press 7 to record an announcement and use #5 to stop)
6) Vtech (HK5886) - preset access code is 48 - enter access code during announcement
#1,2,3 - play new or old messages
#4 - repeat message
#6 - skip message
#5 - stop
#9 - delete message
7) Olympia (OL2410) - preset access code is 0000 - enter access code during accouncement
1,2,3 - select and play messages
4 - repeat message
44 - ignore message
6 - play next message
7 - delete current message
8 - record memo
9 - record announce (5 to stop)
0 - toggle answer on/off
* - play help menu
8) Doro - preset access code is 321 - enter access code right after outgoing message has played (or during)
1 - repeat/skip to previous message
2 - play/pause message
3 - skip to next message
4 - play current outgoing message
5 - record new outgoing message
6 - stop
7 - erase current message
8 - switch off answering machine
9 - switch on answering machine/select outgoing message
0 - (after playback) erases all messages
# - end playback
## - end call
9) Virgin Pulse cordless phone - preset access code is 123 - enter access code during outgoing message
1 - review current message
2 - skip to next message
3 - erase the current message
4 - play all or new messages
7 - repeat voice menu
0 - turn on/off TAD
10) Panasonic - preset access code is 11 or 1111 - enter access code during outgoing message
4 - new message playback
5 - all message playback
1 - repeat
2 - skip
9 - stop
7 - record new announcement (use 9 to end recording)
There are also a few random vendors that don't automatically preset an access code on the machine, forcing it's user to set one up him/herself. This is a small step forward as far as security is concerned, but every vendor I saw that did this still used a mere 2-digit access code. To test and see if your target has this type of setup press # when the machine start, and then press 0. If the machine returns to the annoucement then you know this is the kind of machine it is. Of course, in reality, this isn't all that bad of a scheme since you have 100 different combinations available for the access code. However, most users simply set these access codes as 11, 22, 69, etc. So yeah, just try it out. If it disconnects you after so many tries, call back from another payphone (which you should be using in this case).
Thanks for contacting Fixya
Jun 17, 2009 • Cell Phones
Lost the manual. how do i change the outgoing
You can download the manual at http://uniden.com/pdf/DCT5280om.pdf
Outgoing greeting
Press and hold down the "greeting A" button. You will be instructed as to when to start your message. When you are done recording, release the button. To hear your recorded greeting, press the "greeting A" button again.
4helpful
I Lost my manuel and can't figure how to change or add a voice outgoing message
HERE is the manual! See page 11 of the PDF document which is page 18 and 19 of the manual!
Good Luck!
Brian
6helpful
5answers
Instructions for model 1188
Hi Diana - To record your outgoing message, hold down your ogm button ( outgoing message) for two seconds and it will ask you to record a message. To play back your message, just push the same button and it will play your message. If you don't like it just do it again. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good day.
Jeff
Samsung YP-C1 Need user manual
ineed driver to YP-C1 i cant find it i lost the cd
Top Radio Shack Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Radio Shack Lands Phone Expert? Answer questions, earn points and help others
