Question about Samsung (SC-152) Internal 52x CD-ROM Drive
Cd rom I can not open the cd rom drive to insert the cd.how to open it?What shall i do to repair it at home?
  • Anonymous Feb 03, 2009
    cd rom not open
    Problem Solver:
  • 15 Answers
There are very many problems that It could be when you cannot open the cd rom drive, the best way to find out the problem would be to remove the drive that wont open and open the top, have a look inside and see if there is anything that could be causing this.
If you had a more detailed problem then people might have better answers. sorry
Posted on Dec 29, 2007
Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Mar 03, 2010 | HP LASERJET P1006 Printer
Can't install HP 4355 on windows 7
Installing HP 4355 on windows 7 is pretty easy ,kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,very minute but technical tip is to connect the printer first and insert program CD for printer in the rom drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in nex few minutes your device shall be ready to use.
Incase there is problem with installation with CD kindly go to manufacturers website and download windows 7 compatible drivers.
For Safe Computing Knidly keep your antivirus updated and firewall is on.
Thanks And Regards Kindly rate this solution
Feb 25, 2010 | HP Officejet 4355 All-In-One InkJet...
I HAVE A PORTRAIT CD IT SAYS TO INSERT THE CD-ROM
Click on the start menu in the lower left corner of your display.
Click on "My Computer".
A window similar to this one will open and you will see your CD/DVD drive.
If double clicking the drive does not open the CD, right-click the symbol with your mouse and choose "Play" or "Open".
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 16, 2009 | Computers & Internet
DVD rom restarts xp home
It is the problem of your motherboard check it out to workshop
May 18, 2009 | Sony (2450455) CD-ROM Drive
Gateway M505 internal cd-rom slot does not take in a cd dvd
Not unless you know A LOT about electronics. It's best to just remove the drive and buy a replacement on ebay.
You can either search for M505 drive
or use the part numbers from the drive if you want an exact replacement.
Best of luck!
Feb 25, 2009 | Gateway M505 Notebook
Cannot open the Options bay
On the front of the drive there should be a button. It is tiny. That is the 1st way to open it. 2nd if you do not have luck with that try looking for a small hole in the front of the drive. By inserting a paperclip or small precision screwdiver(like what you would find in an eye glass repair kit) gently insert it into the hole and it will eject the door.
Feb 16, 2009 | Dell (97DMF) Plug-In Module 24x CD-ROM...
Cd rom door can't be opened
When U Insert A Pin Into the hole. does u feel that the pin is pressing some kind of pully? or anything?
if it
Jan 07, 2008 | LG (CRD-8400CB) CD-ROM Drive
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Samsung (SC-152) Internal 52x CD-ROM Drive Logo
142 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
