Question about ViewSonic NextVision N1700w (Black, Metallic) 17" LCD Monitor
ViewSonic N1700w with Black stripe on right side of display
The LCD monitor after warming up has a Vertical White 2" wide bar (stripe) on the far right side of screen. The 2" stripe then will flicker from white to black. Then the 2" stripe will go to all black and stay that way.
If I tap the top of the screen or pinch the palstic together sometimes the display will return to normal, but then starts to flicker again a few moments later. Please Help !
  • daveywavy Jan 18, 2008
    constant 2 inch white bar on the far right side of the screen. ibm 18 inch lcd monitor
  • zrlaszlo Jan 02, 2009
    Same problem with the display of an HP Compaq nx6125 laptop.
    New Friend:
    Problem Solver:
  • 16 Answers
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Posted on Mar 31, 2010
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
ViewSonic VA1926w monitor dims darker when there's dark content on the screen. I have 2 of these monitor connected to a Pro Mac. Only the right side monitor does this.
Its the dynamic contrast ratio (DCR) that dims the display when dark images are displayed.
For my VA1926w, pressing the right most button (up arrow), enables or disables DCR. Keep this disabled.
- Shalabh
Oct 08, 2012 | ViewSonic VA1926w 19-inch Wide LCD Monitor
Vertical 1cm white line,Dell Studio 1737
The LCD Screen is bad, replace it.
May 01, 2012 | Computers & Internet
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
My Viewsonic N3751W lcd TV has a @2" vertical
you need to clean the vedio connector properly inside your tv , if you dont have good idea about electronic you need a technicien
Dec 29, 2010 | ViewSonic N3751W 37 in. LCD Television
Monitor displays wide vertical stripes/bands
That is the symptom of failed T-CON board (part of the LCD panel assembly, new panel will be needed), you can try reseating the ribbon connector on the LCD panel first.
This what T-CON board looks like:
Apr 26, 2010 | Planar PT1814NUV 18.1 in. Flat Panel LCD...
3 shaded vertical bars on monitor about 3 inches
That the sign of failed T-CON board on the LCD panel, new panel will be needed. It will get worst with more lines appear.
Apr 24, 2010 | ViewSonic VX1932wm Monitor
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Monitor distorting in screen halves after warmup
It probably isn't worth repairing as the cost will exceed what you would spend on replacing it.
Sep 11, 2009 | ViewSonic VP201b 20.1" LCD Monitor
ViewSonic NextVision N1700w (Black, Metallic) 17" LCD Monitor Logo
437 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
