Question about Sony Playstation 3 (PS3) Console
PS3 no video
I have a PS3 that powers on but has no video? What is the cause and what can I do to repair it
  • Wes Sydenstricker
    Wes Sydenstricker May 11, 2010
    Everyone knows that solution!! What if you have one that will not reset??
    Problem Solver:
  • 35 Answers
PS3 is The amazing device by sony but it has some common problems like video problem but no sound problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 12, 2009
  • 36 Answers
Maybe your settings got buggered up...
first off, did you ever have video, then it quit?
did you try the cable that comes with the ps3 and then do a video reset? If not, try this
Try this: hook the ps3 to the tv with the ORIGIONAL video cable (the one with red and white audio, and yellow video).
Trun off ps3 with power switch on back. Turn switch back on. press and hold ps3 front power button for 5 to 8 seconds till system double beeps. This resets the video output to standard res. Turn on and see if you have a picture. If not, try another cable. (same cable as Ps2 for this test). If none of that works, you may have a broken PS3
Posted on Dec 29, 2007
Ps3 Turn on and off right away help
Assuming the power cord was securely plugged in, the PS3's action can result from one of the following:
Faulty Power CordFaulty Power Supply UnitPossible shortage somewhere else on the unit cause it to immediately power off.
I would recommend contacting Sony customer service or to a local service repair shop if it's out of warranty. Unfortunately from the looks of the video there may not be an easy fix.
-CS
Oct 29, 2012 | Video Game Consoles & Games
When my son plays his PS3 after a while the screen goes blank and the message: check signal cable appears. His PS3 is connected to tv with an HDMi cable and the cable that fits into the AV with the three...
Try these steps:
1. Before resetting cables, make sure PS3 is turned off using the main power switch on the back.
2. Unplug the power cord of the PS3 and TV from the wall socket.
3. Connect HDMI cable to HDMI Out on back of PS3
4. Connect HDMI cable to HDMI Input port of the TV
5. Plug the PS3 and TV back in to the wall socket
6. Turn the main power switch on the back of the PS3 on.
7. While the PS3 in standby mode(red light on) hold down the on/off button on front of system until the system goes into standby mode again. (So the light cycle would go red light-green light-then back to red. This will ensure you held down long enough to reset video output settings.
8. Turn on the PS3 and once the system finishes powering up, the video output settings will automatically reset.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathon_2815d94e62f0ea08
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
My ps3 won't start
There are many reasons to cause PS3 won't start up, keep turn off with red light. If you send back to Sony or other people to repair, it's just waste your time and money - because the same symptoms will be back again. The best way is learning the repair skills of yourself. There is a PS3 DIY Repair Guide - It's video and text guide that let you know how to open the console, make some minor fixes and recover it at last. The author show his professional repair skills that let you step by step to hands on the repair job. Don't worry your ability to do such things : You will be amazing at last that you can do that yourself. The repair guide cost you not much but helpful. The best part is you can help your friends too!
Sep 21, 2010 | Sony Playstation 3 (PS3) Console
I was using my ps3 and sudenlly it turn off and wont turn on what can i do
You can try to reset the console:
While the PS3 is off (solid red light) Hold down the power button until you hear the SECOND beep, quickly release.
If you're unable to perform the above then you've got either:
RLOD (Red Light of Death - Caused by the unit overheating)
YLOD (Yellow Light of Death - Caused by GPU / CPU )
There are some DIY methods to fix the problem but as someone who fixes PS3's on a daily basis I would HIGHLY recommend you sending your unit into SONY direct for repair.
You can reach them @ 1-800-345-SONY
Aug 07, 2010 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on it powers up for 2 secs and then goes off and a red light flashes
RLOD or dre light od eath is caused by the following problems
1.It might be caused by overheating
2. your hardrive is corrupted and needs to be replaced or reset into the system
3.the soldering on the motherboard needs to be reflowed this can be repaired at a local repair shop that specializes in PS3 gaming console
hope that i could help!!
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
My PS3 powers on then light turn yellow/amber after that you hear 3 beeps and red light starts flashing. How do I fix it. pr is it something I have to send off to get fix?
This can be caused by the unit overheating causing solder on the board to melt and bridge (connect). Once this happens, it shorts out the board causing the the error present now. Contact Sony to see if the unit is still under warranty
If the unit is not under warranty, go to www.wiredextreme.com. We are a console repair company based in Texas and we can get your console up and running again. All of our repairs come with a 90 day warranty that covers the entire console, not only our repairs. We also offer extended warranties up to 4 years at additional cost. If you have any other questions/concerns, feel free to email support@wiredextreme.com or call toll free 1-888-389-3038.
Jun 22, 2010 | Sony Playstation 3 (PS3) Console
How can I fix the flashing red light on my PS3
The flashing red light indicates the PS3 is overheating. This could be caused by: 1. a short circuit in the Power Supply 2. You may need a new fan or 3. the heatsinks may not be making proper contact with the motherboard chips.
If you don't want to deal with Sony we repair the red light error for $79 including shipping. GATpro PS3 Repair
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
When powereing on my ps3, the power light turns green, then yellow then red and blinks
There are many reasons to cause PS3 power light show green, yellow and red then blinks. It's waste your time and money if you send to somewhere repair - because the same problems will be back after then. The best way is to learn the repair techniques of yourself. There is a PS3 DIY Repair Guide : The author use text and video to show you how to use your hands to open your console and do some maintenance and fixes, at last you are amazing that why you can do that yourself. The best part is you can help your friends too!
Jan 31, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont power up. it flashes a yellow light and cuts off. what causes the problem and how much to repair?
The yellow light of death is caused by overheating. When the system gets too hot the motherboard tends to warp and cause malfunctions. They repair for this can run about $100.00.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
Ps3 Video PROBLEM
PS3 is The amazing device by sony but it has some common problems like sound problem, video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
128 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
