Question about Canon PIXMA iP4000 InkJet Photo Printer
IP4000 won't print anything except magenta
I replaced all my cartridges and now the printer won't print anything except magenta? Any ideas?
  • 417 Answers
Hi make sure that the cartridges are fully installed and that you have taken the packaging completely off. Failing that there are two possibilities.
1 Print cartridges faulty or refills
2 Faulty Print cartridge head.
Thanks hope this is of some help
J
Posted on Dec 27, 2007
Canon iP4000. Magenta ran out today, I pulled the cartridge and continued to use the printer w/o magenta cartridge. Picked up a replacement cartridge, installed it and now the magenta does not print.
Hi Todd
I'm suprised you got it to work without the cartridge in it.
You'll probably find that you've burned out the magenta nozzles. The print head works by rapidly heating ink to squirt it out of the nozzle and the incoming ink cools it down prior to the next squirt. It's happening at a spectacular speed and if no cool ink is coming in the nozzles get hotter and hotter until they burn out. Alternatively, they may just be clogged up with dried up residue. Remove the print head and run it under hot water for a while (take the inks out first). Dry it off. refit it and the inks and try again.
Jun 07, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I CHANGE COLOR CARTRIDGES, CYAN AND MAGENTA. NOW,
1) If you've used generic compatibles, that could be the issue.
2) Check out the printer settings for quality, colour and photo correction..
Mar 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma ip1000
as you are telling the problem is inside your printer.please get it serviced.
Apr 05, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Magenta doesn't print
Many printer have a problem with the magenta cartridge...The better way to solve your problem is to replace it again...if you know someone that have the same printer as you or a reseller who will be very nice to try one of is own!!!! After that you will be able to go futher in your search...
Mar 25, 2008 | Brother MFC-3240C All-In-One InkJet...
IP4000 Color Printing Problem
If you have a monochrome option, I would use that.
I'm guessing that your old black and white photo's (which I'm thinking you scanned in may have a sepia tinge which the printer is emphasizing, and if you only want black/white prints, no need to print with colour.
Mar 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Problem with color quality - Canon PIXMA iP4000
i had this problem... its the ink! Check you are using magenta and NOT "photo magenta", and also that you are using "cyan" and NOT "PHOTO cyan"... basically photo cyan, photo magenta and photo yellow are not designed for the ip4000, if you check the smallprint on the box it does not list the ip4000.
This exact problem happened to me and it was driving me crazy. I think the "photo" versions of the inks are for printers that take two tanks of each colour, and the photo version is used for very subtle colours... so if you are ONLY using these inks, photos will appear washed out, yellow etc
Oct 30, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
88 people viewed this question
old marine
old marine
