Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Water spill on Gemini Gas stove
My nine year old poured hot water on to stove while it was on and he was heating water for hot chocolate. Black smoke and electrical smell followed. We have turned off at breaker. What should we do now that it has dried out? This happened 6 days ago. We know nothing about appliances but assume the automatic electric ignition was what was affected.
Not likely turn it back on and try it again
Posted on Dec 28, 2007
Month Old Bunn smells hot
Bunn machine smells hot
* Check for unusual sounds from brewer (other than sizzling from warmer plates). There should be a gradual boiling sound accompanied by some steaming at the top of brewer. This will turn off and ready light indicating the brewer is ready to brew.
* You may sometimes hear a slight boiling sound from time to time (about 15-30 mins apart). Notify your vendor as the warmer blanket may be out. (your brewer will still work but call them anyway.)
* Check your manual for setting up procedures and checks. It's available on line: http://www.bunn.com/product-manuals
* Constant boiling (more than 15 mins) with lots of steaming is a sign of an electrical problem. Unplug machine and call vendor for service.
* Final; Unplug unit and check for 'stuff' in pour over tray. I've found Chocolate, Cream, Milk, powder, sugar, honey, and a dead rat in the tray. Crew will repour old coffee or beverages into brewer to 're-heat' them. Notify vendor for cleaning or replacement (it happens all the time.)
Aloha, ukeboy57
Jan 17, 2018 | Bunn Coffee Makers & Espresso Machines
I think I broke the element when I poured cold water into a heated kettle. Is there a fix for this?
No. Can't happen. Have a Bosch. Always forget to add water before turning on, never ever went wrong. Even if I poured cold water into it 10 sec later. Take it back where you bought it and ask for a refund, or for another one. These are built to withstand these impacts. That's what I'd do for sure.
Dec 04, 2014 | Hamilton Beach 40870 10 Cup Electric...
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
Woodstove smokes into the house
I've never used a ceramic chimney, or seen one for that matter. I know that the dual walled vent pipe works better when warn/hot. Can't explain it real well but the inner pipe gets hot while venting the heat and smoke. And between the inner and outer wall is cooler air, which is drawn down towards the wood burner. Creates a suction by the exhaust out of the center pipe. Mine smokes up the house when I leave the doors open and when it's a low flame inside. I'm sure you've checked on the manufacturers' specs for venting but, if you don't already know, look into the thermal dynamics of a dual walled vent pipe. And also a ceramic as you have. Has to be something with your stove install or vent pipe. Hope this couch advise helps!
Apr 04, 2017 | Heating & Cooling
Acrid electric smelling smoke pouring out of machine when pumping down wash water. motor feels hot to touch.
If you are not overloading the machine, and the front of the motor is pretty hot, then it is going bad. If it smells like rubber, it is the belt.
Jan 14, 2010 | Amana DLW330RA Top Load Washer
Smoke pours from under the range top when a burner is on
[UPDATE} I gathered up the courage and left the element on for a while, carefully using aluminum foil in place of a drip pan. No bad smell. The initial odor was just the residual burning off of the last of the rust/dust. I was worried about directly contacting the hot element with the foil so I made sure it didn't directly touch the element but that was probably an unnecessary concern as aluminum foil has a very very high melting point
Feb 18, 2009 | Kitchen Ranges
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
Kenmore ultra self cleaning oven or top heat
I found that the 220 plug had burned out, that was where the smoke came from. The display worked because the ground "prong" was the only one burned. Had to replace the electrical 220 socked and the electrical plug on the oven.
Jan 13, 2009 | Ovens
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
274 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
