Cable DVR copyright protection with DVD recorder
I have a wideopenwest HD DVR that connects to my 42 LCD by HDMI. I have a phillips DVD recorder also connected to my LCD by HDMI. When I connect my DVR to my DVD recorder I was getting a Copyright error that prevented them to work together. I found that when I disconnected the HDMI from the DVR to the tv that the DVD worked. I dont want to unplug the HDMI everytime I want to record. I can not stop the signal through the tv programming. What can I do?
Palmbeach
  • 185 Answers
SOURCE: copyrighted dvds
Copyright protection is to prevent you from illegally stealing material and breaking the law.
If you Google for DVD copying software you will find lots of programs out there. Do remember though, copying DVDs and Video is illegal!
Posted on Mar 24, 2008
Merkader
  • 21 Answers
SOURCE: VCR copyright
On the side that faces out of the tape that sticks out of the vcr there should be a square indent. This makes the tape read only and tells the player that it is copyrighted. If you were to cover it with a piece of tape it should work. Just make sure the tape is on really good so that it doesn't fall off into your machine. I'm assuming they are your personal family videos that you accidentally broke the tab off of and not actual hollywood videos that you would get into trouble for copying.
Posted on May 01, 2008
SOURCE: how to connect DVR 1600 to LCD HD TV or ATT uverse recorder
Use 2 scart leads from av1 and av2 of the dvd via a spliter .
With the out put from spliter pluged into tv.
(DVR 1600 output is 1/2 of a scart socket and the input is
the other 1/2).
ps:- no auto switching on o/p or i/p!
Posted on Jun 09, 2008
SOURCE: hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
Posted on May 26, 2009
  • 7 Answers
SOURCE: How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
Posted on Jun 06, 2009
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
Dec 26, 2013 | Toshiba DR410 DVD Recorder
JVC Surround Sound System HDCP error message
HDCP...high definition copyright protection.
This means that one of two things have happened;
1) The connection method you used for video from the player to your monitor does not support the decoding of media that is copyright protected such as the Blu-ray format, or;
2) The media you are using is not a valid original recording.
As of yet, the only video connection available that supports the HDCP decoded signal is HDMI. Component video is capable of even greater resolution than HDMI but manufacturers haven't made a way of implementing it's use for copyright protected digital signals. However not ALL Blu-ray or HD-DVD media are copyright protected, that is completely dependent on individual title in which case a component video connection will work.
Dec 12, 2011 | JVC SP-PW100 Subwoofer
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Signal restricted
If your sat dvr is a High Defenition DVR their is a good chance this is being blocked from being copied because of the copyright protection of HDMI...tru to copy to your DVD using just the comosite outs of your sat box...the yellow cable and see if this fixes the problem.
Feb 04, 2008 | RCA DRC8300N DVD Recorder/VCR
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
