Question about Acer TravelMate 2300 Notebook
Laptop wont switch on
I think machine is in either sleep or hibernation mode .it wont open screen
  • 41 Answers
Have you tryed to disconect the battery for about 30 minutes and reconnect it
Posted on Dec 27, 2007
VPCSA does not properly go to sleep / hibernate
My advice is to shut down and unplug the Laptop when not in use. Set the Power Options to High Performance, set Sleep and Hibernate to never, adjust your Advanced Power to shut down when lid is closed. A reboot everyday resets the computer and IF there is a Power Surge your Laptop will not get fried. If left plugged in the battery COULD malfunction and become a fire hazard. Not to mention the unnecessary power applied to components and shortening their lifespan.
May 08, 2013 | Computers & Internet
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Msi cr400 screen flicker problem
There is a big difference between hibernate and sleep mode. One will not wake just by opening the lid. You can get a full answer from this web site:
I suggest visiting that site for a full explanation. It just might be the answer for which you are searching.
Good luck,
Jul 23, 2010 | Computers & Internet
Laptop wont wake from sleep or hibernation
1. you will need to go into you BIOS settings for the mother board to disable the sleep mode.
2. You also have a " sleep mode" in your Windows environment.
Check how to in the "help and support" link at the start button or Windows Orb ( for Windows 7)
Apr 15, 2010 | HP Pavilion dv2000t Notebook
Screen goes blank every 30 second, have to hit the
go to control panel > power options. Turn off hibernate and sleep mode, change all settings to never sleep and change the setting for "when closing the lid" to "do nothing" sleep mode, hibernation can destroy the registry on these laptops, you are better off turning that garbage off and just letting it run.
Nov 15, 2009 | Computers & Internet
The laptop open but i dont screen
If I understand correctly, you open your laptop and you end up with a blank screen. This could be because your sleep and especially hibernate is broken. See the fix here:
Oct 01, 2009 | Acer Computers & Internet
When I close the laptop and reopen it, there is just a black screen and I can't get it to work. So I end up having to turn off the computer. Also when I go to the shut down from the start menu, the standby...
You probably have a sticking hibernate, or sleep button. Near the hinge, there is a tiny pin looking thing sticking up. When you shut the computer, this presses against a switch below the case and puts the computer into sleep or hibernate mode. If this sticks, it won't boot up right. Shut the computer down and use canned air to blow out at the pin opening to clear any debris.
Sep 30, 2009 | Dell Inspiron 1300 Notebook
My name is Luis and my Ibm thinkpad r40 keeps freezing and my screen goes black.
Hi, could be simply your computer is going into sleep mode and not waking back up. try changing your screen saver option to not hibernate or sleep.
Aug 18, 2009 | IBM ThinkPad T40 2373 Notebook
Wont turn on think its in sleep mode. how do i get it out of sleep mode
1.You need to push the power button once. 2.You can also use Alt+Ctrl+Del to wake up the computer. 3.You can change the Sleep/Hibernate to 'Never' n this is how you do it:
Right click in the desktop area (not on an icon) and select Properties Click the tab labeled Screen Saver then click on the Power button Under Power Schemes tab change System Standby/Hibernate to Never then click on the OK button Click the OK button on the Display Properties windows for the changes to take effect. That will Do. If this also doesn't solve the need to call a service person.
Jul 01, 2009 | HP Pavilion dv2000t Notebook
Computers & Internet Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
