Question about Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c530 Portable GPS System
Problems with voice guidance...no sound...any help here? is there a volume control somewhere that is not mentioned in the instruction manual?
  • 174 Answers
The volume control is located on the right side of the unit.
Posted on Jan 02, 2008
  • 504 Answers
You can also try pressing the wrench key at the bottom of the main screen. Then press the down arrow key. You should see a Volume icon. Press this and you should see an icon for Navigation volume. Make sure it is where you want it.
Posted on Jan 03, 2008
Garmin does not read sd card
What size and type of SD card is being used?
The Garmin StreetPilot C530 will not support SD cards larger than 2GB or SDHC cards.
Sep 19, 2011 | Garmin StreetPilot C530 GPS Navigator GPS...
Where should i look for the serial number for Garmin StreetPilot c530 GPS
It will be either on the bottome or on the back. It is only eight digits long.
Nov 19, 2009 | Garmin StreetPilot c530 GPS Receiver
How do you attach a garmin portable friction mount to a garmin nuvi 780?
Your 780 should have came with a plastic bracket that clips onto the back of the unit and the ball of the mount goes into the back of the bracket. Hope this helps!!!
Sep 21, 2009 | Garmin Portable Friction Dashboard Mount...
Using vista, have download it ok but will not transfer data to my c530...can you help
I think there is a problem with Vista driver, contact Garmin for an update to sync program
Jul 11, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin Streetpilot c530
No, it is not possible to configure the unit to do something it is not designed to do. The text to speech feature utilizes a computerized voice with pre-programmed street names. Your unit does not contain this programming.
Aug 04, 2008 | Garmin StreetPilot c530 GPS Receiver
Portable GPS
All of the Garmin automotive GPS units that speak street names are also loaded with basic voice prompts. If one of these types of voice prompts has been selected, the voice prompts will not speak street names.
In order to change this setting on the StreetPilot c550/580, please follow these steps:
  1. In the Main Menu, tap on the Settings icon.
  2. Tap on "Locale"
  3. The second line on this screen has a picture of a mouth. To the right, the current voice for the GPS device is listed. Tap it to change the voice.
  4. Select a voice that is labeled with (TTS) at the end. These voices will speak street names.
  5. Select "OK". The voice has now been changed.
Your device should now speak street names.
Jun 10, 2008 | Garmin StreetPilot c550 GPS Receiver
Reset my garmin streetpilot c530gps
There is no way to just "reset" the PIN. If you don't have the correct PIN, you must take the unit to the location at which the PIN was set. Your only other option is to return the unit to Garmin.
Feb 21, 2008 | Garmin StreetPilot c530 GPS Receiver
No Voice Guidance
Are you sure the volume was up? There is a scroll wheel on the top right side of the unit (as you face it). Make sure it is turned all the way up towards the top of the GPS. You should see yellow bars in the right of the unit indicating the volume level. Also, when you turn the unit on, there is a button on the bottom right that looks like a wrench. Tap this, then press the down arrow on the bottom right. You will see an icon that says, "Volume." Tap it, then check that the "Navigation" volume level is where you want it to be (normally 100%, but that is up to you).
Nov 27, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin Streetpilot 2720
I fixed my C530 on my own. Garmin support will not give you this solution.
I attached the GPS to the computer with the usb cable. I used the file explorer in windows to view the file system on the GPS. I sorted the files by date. Then I moved the files that had a newer date than the last time the GPS worked, to an backup folder on my computer in case I need to restore the files to the GPS again. I than disconnected the GPS from the computer and restarted the GPS. The GPS works perfect now and doesn't enter the demo mode any longer.
Oct 08, 2007 | Garmin StreetPilot c530 GPS Receiver
Volume control gone/no voice
under the front place mark GARMIN take your fingernail and pry it that should do the trick
Sep 19, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
147 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
