Question about Acer Aspire 3680 Laptop
Possibly powerplug! I have an acer aspire 3680 and last night the battery was running low so i put in power cord and my battery just ran out so now it appears dead, thereason i think it is the cord is because if it was battery it wouldnt have been warning me! i hope! Is there any way to check if cord is working, also the green light is on in the cord , pls help yours faithfully D Hamilton
  • 4 more comments
  • donnatella Dec 27, 2007
    pls help
    the power pin had been stuck in the charger i have got it out can you pls pls advice how to put the pin back tightly asits very loose and keeps going back into charging jack pls help
    yours
    D Hamilton
    how do i putthe pin back in tightly as its very loose
    xx
    to whomever answered my problem thanx no i just need some help on putting the pin back correctly pls pls help tyvm
    yours faithfully
    Donna Hamilton
  • darksoul678 Apr 22, 2009
    I have the same problem, but mine is the pin in the jack is very loose and mine wont take a charge.... i need help also.
  • darksoul678 May 11, 2010
    my problem is it is not tight... how do you tighten them???
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
The poor design of the power pin is a major source of problems on almost all laptops. Do a google search for power pin problems and you'll see what I mean.
Problem stems from jerking or tugging on the cable. Every laptop should come with a cable retention device to keep from damaging the fragile power pin.
This video has some pretty good information about it. . .
Posted on Mar 04, 2008
My boyfriend bought his acer aspire 3680 back in april 07. he went to take the power cable out and the dc component inside broke. we had it fixed at a local computer shop within 3 weeks (much cheaper at £60 than sending it away). the socket inside could not be fixed but was replaced with an extended cable with the connector on the outside.
sounds like the connector/jack has an ongoing problem. the laptop is now mine and i have no problems with the extra piece of cable.
Posted on Dec 28, 2007
See if the power pin has dropped out of the connector or if its stuck in the charging jack i have the same problem today
Posted on Dec 27, 2007
I have Acer Aspire 3680-2022 notebook. I still have power instability after buying a new a/c adapter & new battery. When a/c plugged in, battery can randomly & rapidly drop...I get a lot of...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 03, 2011 | Acer ASPIRE 3680-2022 Notebook
I have an acer aspire 3680 computer, Before the battery wasnt working so i bought a new one. Well now the battery came and i tried to charge it, but its not indicateing that its charging and won't charge...
Taking the fact that you already replaced the battery into consideration, chances are that you have a faulty cord. Looks like you're going to need a new one mate.
Sep 16, 2009 | Acer Aspire 3680 Laptop
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
Acer shut down
Souonds like you possibly have a bad power supply. Replace the charger and see what happens
Feb 11, 2009 | Acer Aspire 3680 Laptop
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
ACER ASPIRE 3002WLCI
Probably a voltage regulator, they are usually available on ebay, but I suggest having it done at a repair centre.
Jan 28, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3680 Laptop Can't Power Up
acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Jan 19, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
