Question about HP DeskJet 1220c InkJet Printer
Prints with a shadow behind every letter. Cleaned heads and that page prints fine. Anything through windows doesn't print properly. Reinstalled drivers - running on windows xp.
You have a fault printer cartridge. I had the same problem and bought a new one and now the shadow dissapeared. Take it back to the place you bought it and ask for another one.
Posted on Dec 07, 2009
SOURCE:
Test page prints ok, have cleaned heads, rollers etc but printing is spasmodic or negligible
i can't reset error code i turn on and off the machine but c 3803 still remain.
Jan 08, 2014 | Canon PIXMA MP520 InkJet Printer
Every time I change the ink cartrige, my printer prints with a shadow behind the letters. How do I fix this?
You need to align the printer by printing a test page.Turn the computer on then open the ink compartment remove and replace. The ink cartridge.Then when prompted to print a test page follow the instructions and it dhoud be fine.
Feb 13, 2011 | HP Officejet 4110 All-In-One InkJet...
Top of the page prints fine. From the middle down it prints but also has a shadow or smear of what was printed higher up on the document.
there is a problem in fuser assembly where your prints actually fuses it needs to be cleaned or may need some parts to change
Jan 26, 2011 | HP LaserJet 2100 Printer
Canon MX700 multi-function printer error 5100, double-lines
You can Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All best: Pineworks
Jan 02, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Jun 17, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Slow Printing
it may just be a slow printer head, maybe an upgrade is in order. look on the box for page printing speed.
it may also be that you have the resolution set too high for basic printing. try turning this down slightly.
hope this helps.
kev
Oct 03, 2008 | HP PSC 1350v All-In-One InkJet Printer
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Prints only Black and White (Monochrome)
Check your Printer properties if it is set to color, chances are printer is setup to print in black and white mode or grayscale.
May 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Will not Print Text
Replace print Head/s with new, oand check cost against new printer with warranty and gen new inks probally more economical. Welcome to our Disposable world!!
Oct 19, 2007 | Canon MultiPASS C555 InkJet Printer
HP DeskJet 1220c InkJet Printer Logo
646 people viewed this question
Clive
Clive
Thomas F. Schneider
