Question about Yamaha RX-V596 Receiver
Hooking up this receiver
I have a 50" inch Samsung Hi Def TV/
To enhance the experience i wanted to add a couple speakers.
I know you need a receiver to do this.
My nephew gave me his Yamaha rx-v 596 because he purchased a new one.
The one he gave me is in good working order
Would this type receiver be a good match for the TV i have
I don't see why not. I have a 46" Sony Bravia HDTV that I have hooked up to my RX-V596.
Just use either the RCA out on your TV to the "TV " RCA audio in on the receiver, or if your TV has Optical or Coaxial Audio Out use those...
Posted on Dec 27, 2007
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio Players & Recorders
Receiver & Speakers for Plasma TV
It really depends on how much you want to spend. A home theater set=up will probably be a bit hard to get without a DVD player. Let me know your budget, and I will see what i can come up with. Do you have to stick with Samsung by the way?
Sep 05, 2007 | Audio Players & Recorders
We are trying to hook up our 65" Mitsubishi DLP TV to our JVC surround sound...basically we can get the DVD to work with surround sound but when we have the tv on our sound doesn't come out of our...
That cable doesn't exist. You can't just shoot electrons into one end of a copper cable and have light come out the other end.
My $.02...
Treat your TV like the primary user of the Hi-Def Video ONLY, not the source of any audio. Ask yourself, does it really NEED to be in an audio chain if it doesn't tune the station off the air?
Your JVC should be the primary destination of high-end audio, directly from, say, the Cable Box' while the Hi-Def video is sent to the TV.
Zigzagging good audio and video through the room to devices that don't need it is expensive and wasteful, plus it adds complexity and unnecessary connections that add nothing but could fail.
Feb 15, 2011 | JVC THD-50 System
I have a AVR-591. I hooked everything up and all works great. The only thing I want to know is when I turn off the receiver I have no TV. How do I bypass the receiver so I can watch TV without the reciever...
You said the magic word - BYPASS.
Your TV source is probably a cable or sat box. They usually have multiple audio and video OUTputs and most TV's have multiple audio and video INputs.
Run the box's analog RCA Audio Out to the TV (assuming it has speakers). Set the box's internal volume setting (if it has one) to FIXED and modulate theTV volume with ITS control.
HI-DEF:
Lacking sufficient hi-def inputs on the TV, I'd elect for Component Video from the box and HDMI from your BD player, if you have one. Cable video is bit-rate compromised while BD source is NOT so BD should get the best connection.
I personally have NO high-end video going into my receiver and no high-end audio going to my TV. Why bother with hops?
Jan 30, 2011 | Denon AVR991 Receiver
Trying to connect to LG 60 inch plasma. no output
Hi.
You need to connect the Bose using the Optical Audio output from TV to Bose main unit (kind of square shaped connector), and not using the RCA inputs on TV.
The picture below is an LG back panel, the optical audio connector is at the lower side of I/O connections at the back of TV, on some model the location of connector may be different.
Dec 26, 2009 | Bose Cinemate Digital Home Theater System...
No picture - only sound
Ok, on a hi-def tv, you must have a converter box capable of receiving Hi-def. If you are using a converter box from a satalite or cable tv service, try getting a Hi-def box. Also try hooking a vcr or dvd player to the tv in the non high def ports to varify that this is the problem. If you have any question please let me know, I hope this helps, good luck.
Sep 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
How to connect an audio system to TV
You really can't add too much since the set's amplifier was designed to work with the internal speakers. What you'd be better off doing is buying a stereo receiver (or a home-theater system) and a couple of sets of speakers. Feed the audio output from the TV (on the rear or side, wherever they are on your set) to one of the receiver's inputs and you're off and running. You'll get more flexibility with a setup like this as well. If you don't want to watch TV you could still use the system for radio or CD playing as well.
Jul 16, 2009 | Panasonic VIERA TH-C50HD18 50 in. Plasma...
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
Yamaha RX-V596 Receiver Logo
399 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
