Question about Sony STR-DE675 Receiver
Speakers cut in and out when connected to airport extreme for itunes
I have a cable connecting my Sony STR-DE675 to an airport extreme connection (which is connected to a printer and plugged into the wall) to play iTunes on the speakers connected to the receiver. It worked in my previous home, but now the speakers cut out every few seconds, PROTECT doesn't come on the receiver (and I've moved the speakers thinking they might be too close).
PM44.1 is on some of the time when this happens.
I am using an optical cable to connect the receiver and the airport connection.
Any suggestions on how to fix this (do I need to use a different cable, move the airport? move the receiver?)
5 Suggested Answers
aj97
  • 36 Answers
SOURCE: Airport extreme
Try this in this order:
  1. Verify your aux on the DE675 is working with another analog audio source.
  2. Unplug the G5 -> optical -> DE675 and try playing itunes through the Extreme only into the DE675's aux.
  3. Optical digital audio output on the Mac is VERY fussy, so I'd stay off of the optical unless it's absolutely necessary.
  4. If you're finding that the Extreme is not putting out any sound at all, try this: Reset and update the firmware on the Extreme. Also, make sure your Mac is very updated with the latest iTunes, operating system updates, etc.
Posted on Mar 19, 2009
dunnbiker
  • 8546 Answers
SOURCE: Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
Posted on May 21, 2010
Testimonial: "@dunnbiker Very true on assumptions! I've tried everything the manual suggests. Right now, nothing is connected to the unit, but upon power up, I get the SP:OFF display (which is not seen in the DEMO mode). I will try the headphone jiggling idea and see what happens."
walesarumi
  • 6993 Answers
SOURCE: My receiver is in protect
Your unit being stuck in protection mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in protection mode, then the power supply board in the unit is the cause of the problem. The receiver is trying to avoid further damage, that's why it is on protection mode. Its protecting the receiver. This was how the manufacturer programmed it.
The power supply board might be defective and maybe that's why the unit is on protection mode. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might function.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Jan 26, 2011
SuperTech-11
  • 1591 Answers
SOURCE: My Sony receiver is an
I didn't look up the schematic for this exact model, but many of these units have the surround amps on "cards" just like a computer has a video card or network card, and these can come unseated in a move. Open up the unit, and reseat any cards that are in the unit.
You can check fuses while you're inside the unit as well.
Posted on Jun 21, 2011
Hi, I have a sony STR-DE675.; the audio cuts out between stereo and mono, as if something inside is heating up.I have cleaned all connections and carefully vacumed out any dust from inside the unit.The...
STR is a very sensitive ic module of the audio system and it always has a tendancy to heat up quickly and has some basic precautions to be maintained for operating this. correct speakers should have been connected so on..
if you are technically very confident open up your system try to locate the str ic unit check whether the contacts of the heat sync (aluminium metal chunk screwed with the ic to absorb the heat) has been correctly fixed. (pls note- manufacturers will always have appropriately heat synced it try to use it in a cooler place)
Feb 01, 2011 | Sony STR-DE675 Receiver
May 21, 2010 | Sony STR-DE675 Receiver
Is the STR-DE675 5.1 Surround Sound Receiver compatible with P.C.
Sure! Any P.C. with an audio output jack, like an 8mm phono jack to stereo for example, can be connected to any audio input on the receiver.
May 13, 2010 | Sony STR-DE675 Receiver
Airport extreme
Mar 19, 2009 | Sony Audio Players & Recorders
Sony str-de675 cuts out in dts mode
Your optcal line may have a break in it ! try another opt cable or try useing the digital cable out!
Dec 13, 2008 | Sony STR-DE675 Receiver
SONY STR-DE675 RECEIVER
check the speaker's connections, I got them message when a speaker wire was unplugged and plugged back in while the unit was powered on
Oct 02, 2007 | Sony STR-DE675 Receiver
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Sony STR-DE675 Receiver Logo
421 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
