Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 57H81 Rear Projection HDTV
I called my cable company and asked to get a HD cable box and they asked me if I needed an HDMI or DVI cable with that and it would say it on the back of the tv. Well I have looked and it does not say either. Can I get HD cable channels on this tv?
Your cable company should be able to supply an HD settop box that has component video output for HD. I have one from Cablevison. It is a Scientific Atlanta (SA) 4200HD.
Posted on Jan 07, 2008
WHAT IS THE PURPOSE OF DVI-HDTV CABLE CONNECTIONS AND WHAT TYPE OF PICTURE DO I GET
The DVI cable was the early HDMI cable . all later sets have the HDMI port . when you had it hooked to a DVI source did you select that port with the remote ? if it did not function the port may be damaged . as to picture it should give you a HD quality picture that your cable box is broadcasting .
Dec 23, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 50HDX82 50 in. Rear Projection Television-HDMI to my TV?
Hello
You have to buy one converter box. Your TV does not accept or process HDMI signals.
Dec 08, 2011 | Toshiba 50HDX82 50" Rear Projection...
Do i need hd cables for an hdtv?
If you want to watch some content in HD you will either need to connect your TV to the computer using a VGA or DVI cable, or connect using HDMI(picture + sound transfer) cable to the computer/DVD... You can connect your TV also using Cinch or Scart cables but you will not have HD resolution. Hope this helps!
Oct 11, 2011 | Toshiba 50H81 50" Rear Projection...
55" Philips rear projection HDTV..
that input is called DVI digital video interface it is only for video. there should be some red and white composite input jacks for the audio near the DVI connector. you will need to hookup the red and white cables from the tv to the cable box or dvd player or whatver you are using. good luck
Jan 06, 2011 | Philips 55PW9363 55" Rear Projection...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
