Question about Canon DR-7580
Bar Code Used as Document Name
I need the DR-7580 scanner to detect a barcode and use the barcode as the document name.
Please help me make this happen.
Thanks
  • 24 Answers
You should be able to do that with Canon's document scanning software/Capture Perfect.
Although, you will need to install the "Canon Barcode Module III" which is a separately sold CD, Mfg. Part: 1922B001
Scan-R-Store
Posted on Jan 18, 2015
  • 3 Answers
It's not really an issue with the scanner. The scanner will pick up the image and convert it to whatever you want, but your backend software is what you'll need to mess with for this. Any form recognition software will work (Form Storm, ABBYY FormReader, etc.)
Posted on Jun 09, 2009
Capture barcode at scanner Canon Dr 9080C
You will need to purchase the CD "Canon Barcode Module III" and install it on your computer: Mfg. Part: 1922B001
Then you can select it in Canon's document scanning software/Capture Perfect.
Scan-R-Store
Dec 10, 2013 | Canon DR-7580
Canon dr-6080 getting an error a01 and won't feed paper?
As per the manual it is "In the event of a pick-up error, the document
was fed to the front registration sensors." Clean all the Sensors and try. Use isoproyl alcohol only.
S. Mohan, India
Oct 28, 2013 | Canon DR-7580
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
Sep 13, 2012 | Canon DR-7580
When I'm scanning a document on Canon 7580 each page will show up on my computer screen with a slighly different margin (keeps shifting left to right). The document is being fed into the scanner...
Under CapturePerfect3, you can choose to deskew the scanned image while scanning itself. Also select 'Image only" radio button instead of 'Guide Plate'. The software will remove black borders around the image.
S. Mohan, Chennai, India
Jul 26, 2011 | Canon DR-9080C Path-Through Scanner
Hey, i have a cannon dr-2510c colour scanner and i would like to set it up so that the scanning will go directly to a file on my desktop. i do know to do so i need to go :...
Download and install a copy of Primo PDF ,and as you scan your documents, instead of sending them to your default printer, select "Primo PDF" for your printer name, when your "Print" windows
opens. A Primo PDF window will open allowing to create a PDF of your scanned document.
Make a note of the document name and where you saved it...
Mar 01, 2011 | Office Equipment & Supplies
Canon dr 7580 error code E30
E30 is a Error related to Exhaust Fan. Pls check if the Fan is working, replace if required. If the scanner was used in a dusty environment, the dust can clog the free movement of the blades. It may require cleaning.
Nov 18, 2010 | Canon DR-7580
I have a Canon Scanner DR7580 and the wheels are hesitating upon feeding of the document.
The rollers slip if a) the document is slippery or dirty, b) if they are unclean after usage or c) if there is hardware problem.
Try scanning a set of clean sheets, clean the rollers with a damp cloth thoroughly (no solvents pls). Get QUMA tool and check if the rollers are working independently.
S. Mohan
Mar 15, 2010 | Canon DR-7580
Canon DR-7580 misfeeds intermittantly cutting off about one to two inches of the top section of the page.
Select 'auto detection of page size instead of a fixed size.
S. Mohan, India
Mar 01, 2010 | Canon DR-7580
CANON DR 7580 SCANNER : SCANNED IMAGE HAS A LIGHT STREAK DOWN THE CENTER. LOOKS LIKE THE IMAGE IS FADED APPROX INCH WIDE RUNNING VERTICAL. DOESN'T HAPPEN ON EVERY IMAGE
Assuming the document going through the scanner looks normal, there are a few things to check. If you open Capture Perfect, you can adjust the contrast and brightness as well as the thresholds. Sometimes different toners react differently to the scanner...paper is a big thing too. Multi-part forms can be tricky to get the settings adjusted so you pick up enough of the text but not that on the other side. If it's still messing up, you can try and get it serviced. Ikon is nationwide and can help out.
Apr 24, 2009 | Canon DR-7580
205 people viewed this question
old marine
old marine
