The first thing to check is that the drain is at the proper height. If the drain is too low the water wll just run out. See the diagram that I am attaching. Hope this helped and best wishes.
Was this helpful?
Yes
No
Popular Solutions for GE WJSR2070B Top Load Washer
Would like to Find out HOW to Adjust the Leveling Legs on this Machine. They have a Machine Thread,...
(More)
Would like to Find out HOW to Adjust the Leveling Legs on this Machine. They have a Machine Thread, they are Plastic, and Have a Dowel Pin through the Top which makes it so You can NOT Turn it. So, How do I Adjust these withOUT having to Open up the Machine? Apparently the Legs are Inter-connected from side-to-side//the Back Ones are a "Pair", and the Front Ones are a "Pair"...at this Point my Machine is about 1 1/8" too Low on the Back to Leve...IF I can Find out HOW to Adjust, then I can Lower the Front Legs, and Raise the Back ones...This Out of Level has Already caused the Centering Straps to Break (which I just replaced)...
the tub will start to spin then cutoff, slow down,the tub will start to spin then cutoff, slow down,...
(More)
the tub will start to spin then cutoff, slow down,the tub will start to spin then cutoff, slow down, then try to start spinning again. It never gets up to spin speed. The drain pump is okay. With the front of the cabinet open, i can see the tub start to spin then the clutch assembly shifts as the speed increases then shuts down.
GE washer Model WJRE5500G0WW, serial OM167469G purchased new on 3/26/07 washer works fine, no...
(More)
GE washer Model WJRE5500G0WW, serial OM167469G purchased new on 3/26/07 washer works fine, no leaking water and then there is water on the floor. water level, amount of soap, amount of cloths all do not seem to matter.
i have a GE Model WJRE5500g0WW washing machine. It is two years old, purchased new. After the...
(More)
i have a GE Model WJRE5500g0WW washing machine. It is two years old, purchased new. After the clothes had spun dry, water was observed on floor. Drain tube checked and okay, not plugged up. Before I open the machine up, any suggestions?
