Question about Corona 23-DK Compact Heater
Why am I replacing wicks every 3 weeks
Every 2 or 3 weeks I install a new wick into my heater. I've dumped the entire contents of the old kero and replace with fresh. and still have the same problem. A friend gave me an old kero heater of a different brand and it works fine. It smokes a little when I start it but fires up everytime. So it's not the brand of fuel I'm using.
what' wrong
  • jekyll05 Feb 11, 2008
    Same Problem about 3 tanks of fuel and it's like the wick is not getting fuel or air. I have replaced the wick 3 times and have the same problem all 3 times I've cleaned out tank and used Kerosine from different source. I did notice that when I opened the little door on front that it started burning higher but still not like it use to.
  • eridon Nov 14, 2008
    Scorp 1112 has the right idea. I took my heater to a pro in a shop. The first night I got it home, it worked perfectly. Second night, horrible, all over again. I filled the tank at the same place, but the first time i used it was right after the pro cleaned out my heater and saw water in the tank, which he got rid of. He mentioned condensation, and I think he was right, except neither of us knew what to do about it.
    Anyhow, now I'm back to square one all over again. The wick would not light, except for one tiny thread, which went out. Also, the wick knob is very difficult to turn now, and the wick won't raise properly.
    This is really sad, because I had the heater for five years with no problem at all until recently.
  • 625 Answers
Could be you got the flame a little too high so its burning off the top of the wick.
Posted on Dec 28, 2007
  • 39 Answers
If you already had fuel in it after u replace the wick that was bad then the wick will need replacing again once the water gets into the wick ti wont light well... 2 things that I find that helps is using clean fuel, and I use an additive that helps remove water. My wicks last most of the winter with no problem, But the guy at the hardware store tells me once the wick has gotten watter trapped it it and starts to fail your just time for another replacement wick :(
Posted on Dec 14, 2008
  • 3 Answers
Perhaos it is the quality of the kerosene creating tar deposits on the top of your wick? Have you examined the week at the end of the 2-3 week period? Is it black? Mybe you need to crack the tar and burn the wick dry weekly to keep it going?
Posted on Dec 05, 2008
  • 4 Answers
Try buying your kerosene at a different location. I have the same heater and have experienced the same problem only to find that the kerosene I was buying was contaminated with water.I have found that condensation is not uncommon.Since I found a good source of kerosene ,my heater will run for a solid season on one wick with just a weekly dry burn to clean up the wick.
Posted on Nov 02, 2008
Kerosene heater toyostove rca36has wix full of kerosene and will not light
trim the carbon edge off the wick
wicks work by being saturated in kero and then burning off the kero and not the wick
what you have is a carbon block on the end of the wick that is preventing the kero ignition
Jan 30, 2018 | Heating & Cooling
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
Need a wick and battery pack for a TOYOSTOVE KSA-105, where can i find these?
Hardware stores usually carry wicks. One brand is Kero World. Wick #503K works for the KSA-105. I have one that I bought and the person never brought their heater by so I could replace the wick. The battery pack could be ordered through a Toyostove dealer.
Oct 07, 2010 | Rinnai Toyostove Direct Vent Heater:...
Where can I find an Owner's manual for an Everglow Kerosene Heater or in structions on how to install the wick and burner.
First you need to get the shell off the unit, and get down to the main burner area. There should be 4 wing nuts holding the wick tower down to the fuel tank. These must be removed, and the wick and the adjuster apparatus removed up and over the top of the center tower. Having a towel or old rag handy to set the unit on when you get it off is a good idea, so you can work on it. Remove the old wick, taking care to see how the fabric band on the cloth wick is positioned on the bottom edge of the wick carrier band. Install the new wick at the same level as the old one on the carrier and set it aside. Make sure you clean the tower, especially all the black carbon buildup around the center and near the top. I use a wire brush on a cordless drill to buff the stuff off, works great. Remove the old kerosene from the tank and clean the tank best you can, then put the new wick inside the carrier, down on the tower, being careful to get the bottom portion of the wick down into the tank area, (it should be quite loose down there once you get the rest of the carrier on the tower. Make sure the whole apparatus sets down evenly and fairly easily on the bottom tank part and screw it down with the four wing nuts. I use a paper cup to pour clear, K1 kerosene onto the new wick all the way around the tower, then make sure it moves easily up and down with the height adjuster knob and while it's in a down position, pour some more kero in on it. You can pour several cups of kero on the new wick and then when it's working up and down well, turn it up and lite it before you put the whole thing all back together. It's best to do this outside as sometimes you can get smoking, if you don't get the flame spreader cage on quickly enough. Once it's on and the flames come up and look good, then turn it off, let it all cool off and you can put it back together. Remember, don't use anything but absolutely clean, clear, K1 Kerosene in the unit and burn it completely dry at least once a week, if you use it a lot. It's called dry burning, and it's a wick cleaning function. If you do this, the wick can last years and years.
Feb 21, 2010 | Grilling
How do i change the wick?
You need a pair of Pliers, a flat-tip screwdriver and a plastic bag (for old wick)
ALSO - make sure the tank is empty (or as close as possible)
1. Turn the control knob to OFF.
2. On the left and right side (bottom, just under the wire cage are two cabinet screws. Remove these.
3. Using the handle, lift straight up to remove the cabinet (entire upper assembly)
4. Gently pull off the wick adjustment knob (you will need to push in the little square button.
5. Remove the "dressing plate" (the ring about 3" high) that the "Off" "Low" and "High" markings. The chain attaches this the fuel cap, but you don't have to remove the cap. Just set the "dress plate" ring aside as far as the chain lets you.
6. Either trip the manual shut-off or push against the wobbly pendulum to the left of the control knob shaft to drop the wick all the way down.
7. Remove the four wing nuts that holds the heater on the wick assembly and carefilly lift teh sick assembly from the heater.
8. Reset the automatic shut-off, put the know back on temporarily and raise the wick all the way.
9. Turn the Wick Assembly upside down. Place the white plastic strip, packed with the new Wick, on the Wick Cover to protect your fingers.
10. While holding the Wick Assembly upside down, pull off the Wick Cover with a sharp tug.
11. Remove the Wick while folding it to the inside. (Remove the Wick Sleeve together with the Wick).
12. Take the new wick and insert the Wick pins into the three holes of the Wick Sleeve. (Make sure the short portion of the Wick is UP.)
13. Attach the Wick wo the retainer teeth of the Wick Sleeve stick into it, making sure the Wick fits evenly arount the inside with no wrinkles or bunching.
14. Fit the Wick and Wick Sleeve back onto the Wick Guide, making sure you fit the pins through the slanted grooves of the Wick Guide and Press on each of the three pins from the back, making sure they are inserted securely through the holes on the Wick Guide. (This is where most people screw up Wick Replacement, so make sure you get this right)
15. Turn the Wick Adjustment Knob to make sure the Wick slides up and down freely. (Note, the wick should automatically be set to 3/8 of an inch when fully raised.)
16. Turn the Wick Assembly upside down and replace the Wick Cover by: Align the four tabs on teh Wick Cover with the four screw holes on the bottom of teh assembly and snap it into place.
17. Hold the Set Lever to down position with your finger.
18. Remove the protective strips from the Wick Cover. Turn the Wick Adjustment Knob to the fully raised position and light pull on the "skirt" of the Wick to remove any slack. Then press the skirt lightly onto the teeth on the Wick Cover to hold it in place.
19. Replace the Wick Assembly on the heater WITH THE WICK RAISED. Replace the wing nuts, tightening gradually, tightening opposites sides first(If counting clockwise, tighten screw 1, 3, 4, 2 - go through several rounds, tightening gradually so it seats evenly
20. Before further reassembly, trip the Auto shut-off and reset it to make sure it works properly. Test the Wick adjustment knob to make sure Wick slides up AND down freely.
21. Remove the knob and replace the "dressing plate ring.
22. Replace the entire upper assembly "Heater Cabinet" and repalce the two screws. Replace the Wick Adjustment Knob.
Oct 11, 2009 | Corona 23-DK Compact Heater
RMC-95C6 wick replacement
REPLACEMENT WICK NUMBER: Kero-World 32225, Dura Heat DH-145, Glowick 30856.
Sep 07, 2009 | Dyna-Glo RMC-8001SS Heater
I need to change the wick on my dk 23 corona kerosene heater
what make and model is it? They are very simple to change,never heard of 1 "Not" lighting tho,unless you have water in tank and the wick sucked up the water...water don't burn,You can also raise the wick in their now if it has never been raised,as long as it don't have "riviet"looking things attached to sides of wick to fit it wick housing(Sears is good for that)If it a round or square heater it pretty much the same you have to remove the outer shell of heater, its always a good idea to dump out fuel first,at the base of wick their is usually 3 wing nuts or screw that hold wick Assembly in,after removing them you pull housing up to remove ,notice how the old one is on and remove and put new one on,when putting back in make sure wick fans out and goes to bottom tank,put back to gether and your done,most replacement wicks come with directions and height setting for the wick, Its not real hard as long as you pay attention
Nov 26, 2008 | Heating & Cooling
Kerosene heater will not wick up fuel from tank properly
Have you checked the length of wick. May not be long enough to get down into fuel. RON
Jan 26, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Wick trouble
the wick is held onto the moving mantle with pointed pins protruding from mantle. remove the mantle assembly and remove wick. then, if wick looks charred black on top, clean top of wick by trimming evenly all around with very sharp scissors; otherwise, use stiff brush... then assemble wick to a location that will be about 1/4 to 1/2 inch higher than when removed. may as well flush out kero tank before final assembly.
Jan 24, 2008 | Corona 23-DK Compact Heater
Dyna glo RMC95C6 kero heater
I suggest you replace the wick and clean the wick feeder assembly. I did not own that model but did have one a number of years ago. The wicks can begin to dry out.
Jan 08, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Corona 23-DK Compact Heater Logo
496 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
