If you are using an S Cable then it is either not securely fasened or there is a problem with the cable or pins. Make sure the cable is secure (moving it should bring color) or try another cable. If the problem continues you will need to replace the connector on the unit or TV one. Good Luck.
There might be any problem in ur vedio card or check for drivers.........or else it is a problem of the display which u need to change
