Question about BNi Joycoder PV-380 (40 GB) Digital Media Player
Joycoder pvr380 help pls!!!
Hi there,i got seious problem with my player,i swapt harddrive with brand new one,i set it with new firmware but when i turn it on its sayin:SE ERROR PLEASE CHECK..if you can help me with this i will be so happy,thankyou already,,
0 characters
1 Points
How do i delete music already on there
hi there,
for erasing the data on it you perhaps can find such option by either browsing the data management or settings section in the player's menu or by hooking it up to a PC and erasing the music files on it by using the windows explorer(handle player like a small external harddrive, but just delete the unwanted files, do not format(!) it as this will erase the firmware (necessary for the player!) )as well.
good luck
Sep 07, 2009 | Philips SA3025/37 Flash MP3 Player
Creative Zen Touch has no firmware installed
then i would suggest you to reinstall the firmware of the player once.
this will clear the problem
Aug 18, 2008 | Creative Labs Zen Touch MP3 Player
Appreciate the direct "Ask Me".
For most Archos products, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 06, 2008 | Archos Jukebox AV380 80 GB Digital Media...
Hi cheebs
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
-Tha Mp3 Doctor
Apr 23, 2008 | SanDisk Sansa E280 MP3 Player
Creative Zen Touch firmware problem
This means both systems contain a bug, or cookie. If the firmware you accessed isn't applying itself to the device, this means the system itself has been corrupted. Double check with your system configuration properties on each device, and tell me whats going on from there.
Don't panic!
Mar 25, 2008 | Creative Labs Zen Vision Digital Media...
Pi would like to get my player back,pls...
go to click on downloads then click on firmware and follow the instuctions !! =].. i had the same problem!! all my music got deleted but it works again !!!
Feb 29, 2008 | Archos 405 Digital Media Player
If your PC still recognizes the player, you can try to drop the firmware update onto the players mass storage area. Once you disconnect the player from the USB cable, the player should begin to update the firmware.
If this doesn't work, let me know. I can look into an alternative method for fixing your player.
Sep 19, 2007 | Insignia NS-DA2G MP3 Player
Pls help my e250 sandisk
Hi please try this steps. Turn off the player. Slide the hold switch to the other end for it to show the orange/red color. Then press and hold the menu button until it says welcome to recovery mode. Then if you haven't updated the firmware of the player this would be the best time to do it. Donwload the firmware update at their website and run it on your computer. When it asked you to connect a device connect the player and perform the update for the player hope this helps.
Jun 15, 2007 | SanDisk Sansa e250 MP3 Player
BNi Joycoder PV-380 (40 GB) Digital Media Player Logo
Top BNi MP3 & Digital Media Players Experts
Are you a BNi MP3 and Digital Media Player Expert? Answer questions, earn points and help others
