Question about Car Audio & Video
How to connect two amps do i connect one amp from battery and then take power from the other or must i connect bofe of them from the battery and how do i get rca cable to the other amp my stereo only has one rca out i have i two in to four rca cable the amps are 4 channels do you get a splitter
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Run a single wire to battery fit it to a distribution or connector block they normally come 1 into 4 or 1 into 2 ,and yes you can get splitters for your rca cables should be able to pick them up at your local car audio dealer.
Posted on Apr 20, 2008
Connected a Dual XPA2100 300 watt amp to the battery and connected ground to chassis of vehicle. Vehicle is 2004 Saturn Ion with battery located in trunk area. Amp does not power on, all connections are...
The remote wire DOES need to be connected to the head unit. You can see if thats the problem simply by touching the remote wire to the power wire. The unit should come on. The head unit should either have a remote lead, or a power antenna lead, and thats what you need to turn the amp on and off. BE SURE your ground is solid, and its usually best to take that to the battery as well to prevent unwanted engine noise. Hope this helps!
Sep 25, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Laptop not starting properly
follow these steps & ur issue might get resolved(80% chances):
turn off ur notebook-->take out the laptop battery(not the cmos battery)-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved, turn off ur notebook again & restart to ensure that its not reoccuring....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Jul 11, 2010 | Computers & Internet
Blank screen when turned on, then there are 2 lights that flash they both have a lock symbol before them one is with an A and the other is with a 1. Everything else lights up but screen is just blank/black
turn off ur notebook-->take out the battery-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Jul 08, 2010 | HP EliteBook 6930p Notebook PC
I have a acer one i tried the bios reset but my kid push the power button in the middle of the reset and now its not power at all , help.....
Hi there!
Try by removing the battery! Now press the power button without AC adapter connected to discharge remaining current inside. Wait 2-3 minutes.
Connect the AC power only & hold power for 20 seconds for a reset. Test.
Insert battery & test if problem is not solved.
If all the above don't work, you'll need to take the netbook apart, locate the 3V coin-cell battery on the motherboard & wait for 1 minute to erase CMOS. Replace battery & test.
Please send us your valuable feedback & vote to rate the advice.
Mar 05, 2010 | Acer Aspire One PC Notebook
No Power Using AC Power or Battery
I had this same camera. If you have a power fluctuation it can really damage the batteries. make sure it was not exposed to fluctuations
Jan 26, 2010 | Panasonic VDR-D100 DVD Camcorder
I install wire from the battery to the amp ground the amp then i installed the audio jack from the reciver to amp an then the speaker wire an nothin
Power amps must be connected + battery wire to the amp +b terminal with a gauge 8 or bigger depending on the power rating, - ground to the car chassis as short as possible,connect cords from head unit to power amp with good groundings, and remember to connect the speakers and the remote trigger from head unit to turn the amp on.
Aug 27, 2009 | Performance Teknique ICBM-772 Car Audio...
The amplifier keeps on blowing out the fuse when i connect the battery
Start by dis-connecting the power lead at the amp, and securing it (where the bare wires are not touching ground) Now insert a new fuse then make the battery connection. If the fuse blows then you need to trace the power wire to find the short, or replace the entire wire, paying close attention to sharp edges and pinch-points that could cause this problem to reoccur.
If the fuse didn't blow, dis-connect the power lead at the battery then all of the other connections at the amp, reinstalling the power lead to the amp. With only the power lead connected at the amp and the good fuse inserted, reconnect at battery,and if the fuse blew then the problem is with the amp. and should be repaired or replaced depending on its value and the cost effectiveness of those two options.
If the problem has not yet been discovered, continue with tracing each of the remaining amp wires in that manner, as been described above.
Good luck...
Feb 23, 2009 | Directed Extreme XA-5001 150W x 1 Car Amp...
Maystar cx475
Ok, I am assuming this is the 600 watt amplifier?
DISCONNECT YOUR BATTERY!!
Supplies needed:
- 8 Gauge power wire (long enough to run from your battery to the amp placement) WITH an inline fuse!!
- Depending on your stereo (if it has amp pre-outs or not) you will either need RCA cables (long enough to reach your amp from your stereo) OR a Line-Out converter AND RCA cables.
- The power lead that connects to your "REMOTE" line on your stereo (long enough to reach from amp to stereo - usually blue)
- A good ground wire ( long enough to reach a metal part of your car from the amp)
STEP 1: Find a spot to run the power wire from your battery - through your firewall and into your car - and then to your amp. (DO NOT CONNECT IT TO ANYTHING YET)
STEP 2: Remove your car stereo and look to see if you have PRE-AMP outs (RCA connectors for an amp on the rear of the unit)
A- if you do, GREAT.. proceed to step 3
B- if you don't.. you will need to get a LINE-OUT CONVERTER - what this does is converts the higher signals from your standard wires on your radio, to RCA style wires to connect to your amp.
B2- you will also want to buy a wiring harness kit for your stereo, unless you want to hack away at your factory wires.. (not recommended) - connect the harness kit to your factory wire harness, wire in your leads for the output converter, and run the other end to your stereo.*
*you will need to know which wires run to the speakers you plan to power with the amplifier
B3 - once the converter is properly connected - proceed to step 3
STEP 3: Plug the RCA cables into the stereo or converter, and run them properly from behind your radio to the amp but DO NOT CONNECT THEM YET.
STEP 4: Connect the REMOTE wire from your stereo to the same wire for your amp . (this enables the amp to turn on/off with your radio.. otherwise.. you will have alot of dead batteries)
STEP 5: re-install your stereo into the car.
STEP 6: Connect the RCA speakers into the INPUTS on your amp
STEP 7: Connect the REMOTE wire to your amp.
STEP 8: Connect the speaker wire from the OUTPUTS on your amp to the speakers you wish to power
STEP 9: Connect the POWER CABLE to the amp PROPERLY
STEP 10: Connect the GROUND CABLE to a metal part of your car (sheet metal, not just a bolt)
STEP 11: Connect the POWER CABLE to the battery cable
STEP 12: Re-connect your Battery
STEP 13: Start your car, and test your radio.
If you have any issues from here.. you need to re-check all of your connections.
Oct 12, 2008 | Car Audio & Video
3 amps 2 subs sound system for car, need wiring help
As i read your problem i can recommend you that connecting each of the hifonics amp to each hifonics sub with the same specs by getting the specs in interfacing the two or you can simply look to the output of the amp and the input of the sub and find a suitable plug that fits to them.
In the case if you want to run each hamp to individually run each sub but sharing 3 farad capacitor: what i can suggest is that you connect in parallel one connecting wire of each input or ouput of the amp or sub. Its like connecting a connector from each of the input or output of the amp or sub to one leg of the capacitor, and connecting two wires to the other leg, one is being connected to the amp or sub and the other wire is connected to the other amp or sub.
In the case of putting a circuit breaker at the car battery: what i can suggest is that you find an appropriate circuit breaker that fits the specs of the car battery then connect it in series on the positive supply or read the specs of the circuit breaker before you connect it to the battery. Having a circuit breaker is like having a fuse but with special advantages in favor of the circuit breaker.
In the case of having power to the amps you can run one power wire to the amps by dividing the power wire into two, one connected to the amp and the other wire to the other amp. Then you can connect each amp and sub in series individually by connecting one wire b/w amp and sub. I hope i solved your problem
Feb 08, 2008 | Car Audio & Video
Amps
You can run one power wire from the battery into a power block. Power block can feed up to 5 other devices.
Dec 26, 2007 | Car Audio & Video
Car Audio & Video Logo
674 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
