Question about Sewing Machines
Juki mo 134 threading
Hi, I'm having trouble with the left needle thread breaking. It was threaded when I got it from an auction, so I just tied threads together to put new thread on, so not sure if it's threaded correctly. Can you help, is there any place I can get a manual? Thanks Karen
  • burnergirl Jan 07, 2008
    need a threading diagram too please!
    amalin
4 Suggested Answers
SOURCE: juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
Posted on Sep 10, 2009
  • 1116 Answers
SOURCE: Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Posted on Feb 19, 2010
SOURCE: JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Posted on Nov 18, 2010
I am having trouble threading the needles of my Juki MO-2516M serger
Be sure you are using a needle size suitable for the thread weight you are using.
Try this method for threading needles:
Lick your index finger and swipe it across the back of the needle eye.
Aim the thread cut end above the needle eye and slide it down to the eye. It should go right through the eye.
Jun 06, 2018 | Juki Sewing Machines
Using Juki DDL555, Thread breaks when trying to hem jeans
Sometimes using a larger needle will help. That is if it's shredding the thread when it goes through the needle which causes it to break.
Mar 25, 2013 | Juki MO-644D Mechanical Sewing Machine
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
The thread on my juki 816-dd4. How do I retread
Here you go Angie: look on page 6 of this pdf. I recommend that you print this, put it in a zip lock bag and tape it to the underside of your table.
http://www.raichert.com/adobe/MO804-12-16%20Inst.pdf
Basically Any serger is threaded like this.
Upper looper, Lower Looper and then needles from left to right. Any time you break a thread you have to start from the beginning taking the thread out and starting over.
If you want to change colors. Clip the threads near the spools, change out the color and tie the thread to the previous color... gently pull through the thread path to the needles. Clip the knot and thread the needle.
Jul 30, 2012 | Juki Sewing Machines
JUKI MO 134 SERGER
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Good diagram showing how to thread a 4 thread Juki 644d serger we do not have a manual machine is not clear
You can download a free threading guide here - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_644_Threading_Diagram.htm
The same site also sells manuals.
Threading Tips:
Have the thread antenna at it's highest position.
Set the tensions to zero.
Have the presser foot up while threading.
When you thread a serger for the first time, or if you are having a threading problem, use a different color thread for each guide. This can quickly indicate where the problem lies.
Once the stitch is satisfactory, change to the color you prefer - but this way is the easiest - cut the thread near the thread cone and tie off with the new thread. With the tensions at zero, slowing run the serger until the new thread appears. You will need to stop as the knots approach the needles and thread them by hand.
Do the tie-off before running out of thread and this will save a lot of time and stress.
Mar 02, 2010 | Juki MO-644D Mechanical Sewing Machine
Juki mo 2316 nEEDLE THREAD KEEPS BREAKING
Thanks anyway!
Sep 09, 2009 | Sewing Machines
THREADING FOR JUKI MO 357
Put new needles in it.
Following the colors, thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
Jun 27, 2009 | Juki MO-644D Mechanical Sewing Machine
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Mar 11, 2007 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
230 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
