Question about Copystar (023-JF503) Fax
Print full year fax logs
I want to print full fax logs from 1/02/2007 till date but when i gave command from printer it has printed only last 30days fax logs
  • docman1 May 11, 2010
    That is true
  • 52 Answers
Most fax machines only keep track of faxes for 30 days or so many faxes then deletes the oldest one when a new one comes in. hope this helps to clairify.
Posted on Jan 04, 2008
Is it possible to print of a fax log that is older than 30days
I would try seeing if they have an answer on the manufacture website. Typically not. :(
Mar 01, 2011 | Office Equipment & Supplies
I recieved a fax a few months back that i cannot find it , does the the hp 6310 all in one have a memmory log so i can access the document again?
You can give it a try, hopefully the printer should be able to print the fax log if it hasn't erased it.
Press Setup Button on printer front panel
Scroll to Print Report - Press OK
Scroll to Fax Log - Press OK
Check the fax that you had received on the date and press ok or it may print the fax log present in the printer.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 19, 2011 | HP Officejet 6310 All-In-One InkJet...
Can I "reprint" a fax from the memory (log) in the
The printer does not has Re-print option, although you can print the fax from Fax Log option.
Press the Setup button printer
Use Arrow key till you find Print Report - Press OK
User Arrow key till you find FAX Log - Press OK
Regards,
Shawn
Jan 06, 2011 | HP OfficeJet 7310 All-In-One InkJet...
How do I print the fax log?
Follow the steps below to print Fax Logs for already received faxes
  1. Press Setup , and then press 2 . This displays the Print Report menu.
  2. Press the Right arrow button to scroll through the following report types:
    • Fax Report Setup: prints the automatic fax reports as described in Generate reports automatically.
    • Last Transaction: prints details of the last fax transaction.
    • Fax Log: prints a log of approximately the last 30 fax transactions.
    • Speed Dial List: prints a list of programmed speed-dial entries.
    • Self-Test Report: prints a report to assist in diagnosing print and alignment problems.
  3. After the desired report is highlighted, press OK .
Also, Click on the link below for more information about Fax settings on your printer
Fax Settings
Dec 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Just want to know how to print the fax log?
Please find the below steps to print fax log for Officejet 6210 all in one.
  • Press Setup , and then press 2 . This displays the Print Report menu.
  • Press the Right arrow button to scroll through the following report types:
  • After the desired report is highlighted, press OK .
Regards
Riztech
If this solution is helpful,kindly vote 'thumbs up' and testimonial.
I would like to print a transmission report for a document that I just sent.
Hi
You can print a log of faxes that have been received and sent by the device. Each
entry in the log contains the following information:
• Transmission date and time
• Type (whether received or sent)
• Fax number
• Duration
• Number of pages
• Result (status) of transmission
To print the fax log from the device control panel please follow the directions below
1. Press Setup.
2. Press right arrow to select Print Report, and then press OK.
3. Press right arrow to select Fax Log, and then press OK.
4. Press OK again to print the log
All the best!!
Regards
Nov 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
Printer does not print stalls at 29%
Try reinstalling (remove icon in Printers and Faxes and reboot system).
Hope this helps.
Aug 17, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Laserjet 1022 does not print the full date in voucher
adjust the page setting through pagesetup .and then check out in the print preview first before giving the print command.
Dec 10, 2008 | HP LaserJet 1020 Printer
Hp 1200 business inkjet help
I have a solution that is very similar to that printed above.
I have tested it on five installations on the computers on my home network and an HP Business Inkjet 1100, and the PCs running Win XP SP3.
Step 1) If you are setting up the printer from the HP CD, decline the question where it asks if you want to print a test page, (this will avaoid the first print job before re-setting the dates).
Step 2) Reset your clock back to a year prior to the year when your cartidge expired.
Step 3) Print a test page, or two. Or a few pages from any application.
Step 4) Reset your clock back to the current year.
The printer now prints fine. Since I performed the sequence above I have been printing with the "expired" cartridges for a few weeks. I have printed on about 15 occasions over the past few weeks, amounting to about 50 pages. No problems so far. I don't know how long this solution lasts or whether I will have to go through it again.
I have gone through a few different "solutions", including a Registry hack that didn't work, but this simple solution above has worked every time on five different installations.
I did not need to turn the printer on/off, and did not need to re-boot the computers.
However, if I sent a print job to the printer before performing the sequence described above, and the printer gave an "expired cartridges" error, then I would need to turn the printer on/off to clear the error, and flush the print queue.
Jan 28, 2008 | HP Inkjet 1200dn Printer
117 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
