HP Compaq Presario 2200  PC Notebook
Problem for HP Compaq Presario 2200 (PK800AV) PC Notebook
Presario 2200 laptop won't start up-goes to
By burdfrenzy on Oct 15, 2009
presario 2200 laptop won't start up-goes to windows then shuts down-blue screen says: "A problem has been detected & windows has been shut down to prevent damage to your computer" Technical information:
stop: 0x00000024 (0x00190203, 0x85352108, 0xc0000102, 0x00000000) any sugestions? Can you help? thank you vm
Joe from Tampa
Best Solution
posted on Oct 15, 2009
Very Helpful)
SpideRaY
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 123 votes
Did you do this below?
This is called the BSOD (blue screen of Death) this usually occurs if you have recently installed either a new piece of hardware with a driver that has conflicted with Windows.
1. Unplug all you USB peripherals while the PC is shutdown
2. Press F8 while the PC is booting up its difficult to know when to do it so I usually press it twice with 5 seconds between presses.
3. Select last known good configuration and see if your PC will start this might be all that it needs.
If this fails unless you have a boot CD that allows you to recover the DOS or on some laptops like Evesham they have PC angel installed I am not sure if the Compaq Presario has this but you can use Hirens Boot CD or some other to try and restore the files,
I am sure that the CAB files that are required will still be on the laptop unless someone has removed then to save space.you may have to take it back to factory defaults, you will loose all installs and documents though its a bit drastic but it should get you back up and running.
Hope this helps please rate my post if it helps you.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" IT DIDN'T HELP BUT I DO THANK YOU " - burdfrenzy
Solution #2
Somewhat Helpful)
ckuzkuz
Rating: 88%, 48 votes
I think you should try to restore your windows. It's probably resulted by some information which got deleted, or maybe an installation of a program or hardware which clashes with the system.
if you have XP on your computer, it's pretty easy. on most laptops you can access the restore by pressing F8 or F12. then you will be able to choose "last known good configuration" and that should solve it.
tell me if this doesn't help, and I will guide you further
Was this helpful?
Yes
No
Popular Solutions for HP Compaq Presario 2200 PC
Questions and Unsolved Problems for HP Compaq Presario 2200 PC
Do you recommend HP Compaq Presario 2200 (PK800AV) PC Notebook?
Answer
Answer
I need windows 7 driver to Acer Aspire 9500 wireless (Intel) card. On the Acer drivers page there... (More)
Answer
where can i buy a vaio sony laptop pcg - 3e2L
Answer
I have a problem with Gateway Laptop W340UA. The lights of the hard drive > and CD Rum are... (More)
Answer
modem is working but doesn't show in internet connection
Answer
hi HP Compaq Presario 2200 PC Notebook Usb problem usb not work any idea about solve this problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
