Home | GE | GSS20IEP Side by Side Refrigerator | No water from dispenser
GE GSS20IEP Side by Side Refrigerator
Problem for GE GSS20IEP Side by Side Refrigerator
By skasanago on Oct 15, 2009
When I press, water is not coming at all from dispenser, If I change to ice cube, ice cubes are coming from dispenser. GE model number GSS22WGPH BB
Same Problem
Oct 29, 2009
-   My ice dispenser keeps freezing up and clogging. It appears the flapper that closes after ice is dispensed does not close all the way and seal to keep warmer area and humidity from entering the freezer. Is there a way to tighten the tension on the spring flapper?-   frankbama737
Best Solution
posted on Oct 15, 2009
Very Helpful)
57 varieties
Rank: Guru
Rating: 88%, 510 votes
As you have ICE then the most likely a fault with the water dispenser valve. It may also be a fault with the controller board. You can try resetting the Fridge Freezer by switching off the mains line power for approx 30 minutes and not opening the doors pr pressing any buttons during that time. Then turn the power back on and see if the fault has cleared. If not then you will need the valve or controller replaced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE GSS20IEP Side by Side
Questions and Unsolved Problems for GE GSS20IEP Side by Side
Do you recommend GE GSS20IEP Side by Side Refrigerator?
Answer
Answer
ice maker works great, water line quit dispensing
Answer
ge profile side by side - freezer nor refrig is getting cold - about a month ago the freezer had ice... (More)
Answer
converting one ice-maker from one fridge to another
Answer
first ice dispenser and water dispenser were slow to trigger, then stopped working with dislay... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE GSS20IEP Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
