Question about GPX MWDT8826SP MP3 Player
Can't get the radio feature to work.
Menu sequence as described in manual does not appear to match what actually happens in unit.
0 characters
1 Points
How do i make my mp3 mw353 shuffle
"Menu Press to access the menu and make selections. Use the Skip/Search buttons to navigate the menu. In Play mode, press to set the EQ or repeat settings. In Pause mode, press to access the local folder and delete options."
Ok this operation is the same with my ml961. I found this in the pdf download for your unit. Hole the menu button for a few sec 3-5 release you will be in a menu to set various features for music.
This should be in the manual that came with you unit. I had to go through mine a few times to find it Then I was looking in the wrong spots of the manual. I know a lot of us figure we can figure it out right off that bat but unfortunately GPX did not make that easy. here is the link to download the manual it is only in pdf 4GB Digital Audio Player MW353B GPX
Hope this is of help.
Jun 27, 2014 | GPX MP3 & Digital Media Players
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
»» The radio automatically tunes radio
stations and saves the frequencies to
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
I have a 4 gb Sansa Clip. How do I switch back
You can go to the main menu on your player and select which one you want to use at a time. Here is a manual that describes everything you need:
Page 6-7 has the menu options/controls that you can use to do that.
Oct 31, 2009 | SanDisk Sansa Clip MP3 Player
Radio problem
Philips printed the same manual for the US and the UK. The radio feature is only available on the European models.
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GOGEAR SA6045 MP3 Player
So, what happened when you connected the thing to sync with a PC and rightclicked on the tool-tray item for the Gigabeat?  Maybe you got a menu about Upload Portable Media Center?  If not, go into applications and see if the gigabeat stuff doesn't happen to contain the bespoken user manual.  Open it....  Usually there's a little button-sequence to prepare the player and another to restore the Portable Media Center program.  Happy discovering.
Jun 16, 2008 | Toshiba gigabeat MES60VK Digital Media...
Ipod troubles
Put the switch on hold then unhold it
now press the center and the menu button simultaneously for about 6 seconds
till the apple sign appears.
May 27, 2008 | MP3 & Digital Media Players
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
FM Radio Feature Completely Disappeared!
Yes this is a common problem with no soultion. could try taking it apart and reseting all the connectors inside see if that works?
Jan 08, 2008 | Creative Labs ZEN Vision:M Digital Media...
SANSA e260 4gb
p.20 of manual:
Sansa Media Converter software lets you convert photos and videos as appropriate,
and then transfer them to your Sansa player. Sansa Media Converter offers
features such as cropping, rotating, and resizing before transferring them to your
player as well as the ability to transfer photo and video files to your microSD card.
Refer to the Sansa Media Converter software for file formats supported.
To transfer photos and videos to your Sansa player, follow these steps:
1. Connect the Sansa player to your computer.
2. Select Converter using Sansa Media Converter on initial connection.
3. Click Add Media to select photo or video files to be converted.
4. The Sansa Media Converter will store all converted files in My Album. Click
the Album Name box and type in the name you want.
5. Click to start the conversion process. A status box will appear
showing which file(s) are being converted.
Dec 10, 2007 | SanDisk Sansa e260 MP3 Player
Empty song list
Here's what happened: When you first synced your player to Windows Media Player, you may have set up the automatic sync option. When this option is selected, Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the player. Now, every time you sync you device, it adds every new file from your computer into the player automatically. It will even delete songs from your player that were on there before.
Go into Windows Media Player 11 with your player connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portable media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding/deleting songs/files you don't want into your player.
-Tha Mp3 Doctor
Apr 10, 2007 | Philips GoGear HDD6330 MP3 Player
GPX MWDT8826SP MP3 Player Logo
15 people viewed this question
Top GPX MP3 & Digital Media Players Experts
Are you a GPX MP3 and Digital Media Player Expert? Answer questions, earn points and help others
