when i put the washing on, the machine just keeps filling up with water after it is full, is there some sort of float valve or something that might be broken.
Check for a faulty water level/pressure switch. This is a diaphragm like device with a small plastic tube (which you were blowing into) attached between the switch and the bottom of the washer's outer tub. As the water level rises, so does the pressure on the air in the plastic tube and when it reaches a certain leve it activates the switch to shut off the water. Make sure there is no obstruction in the tube and that it is not damaged in any way. The switch can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity will mean a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Was this helpful?
Yes
No
Popular Solutions for LG WFT1071TP Top Load Washer
my lg washing machine wf-s6607tc soon after start washing it stops then spin and drain lights comes....
(More)
MY LG WASHING MACHINE WF-S6607TC SOON AFTER START WASHING IT STOPS THEN SPIN AND DRAIN LIGHTS COMES. AFTER READING THIS SITE I GOT TO KNOW THAT THERES A MAGNET ON THE TOP FRONT COVER. SO I BEGAN SEARCHING FOR THE MAGNET. BUT ITS GONE.. SO WAT ELSE CAN I DO?
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and...
(More)
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and once first part of cycle is in motion it over flow. Please send drawing of machine and where load sensor is located.
My fully automatic Fabricare LG machine just stops before the spinning process has to begin. We need...
(More)
My fully automatic Fabricare LG machine just stops before the spinning process has to begin. We need to rearrange the clothes or spin twice reducing the quantity to half.We do not over load the machine too. And some muck gets on the clothes from some part of machine. Please help.
