Question about Nintendo DS Lite Console
HELP!...need to fix L2 black box to the motherboard in a Nintendo DS lite
Hi! My neice dropped my daughters DS lite and it would not turn on so I opened it up ad found that a circuit box in the L2 quadrant(far left side on the motherboard) had been knocked off. I put the little box on and pushed it and it stuck? This resolved the problemfor 2 days until it got bumped and the peice fell off again. I need to know to afix it back....I tried a saudering kit but I got too much sauder on one side and it would not come on...so I have removed it again...What do I do know? Thanks so much for your help!!
  • 1 more comment
  • giu-bot
    giu-bot Jun 06, 2008
    I, Have the same problem help me.... the value of the L2 ?
    Best Regards...
  • neelyjoey2 Jun 24, 2008
    we drop ours also but it works just the hige is broken and i am not sure where to send it to get fixed jennise
  • Anonymous Feb 17, 2009
    fixed, solution works THANKS
My daughter's friend had the same problem. Soldering was difficult, but repaired the problem.
I used a very fine solder and 15W soldering gun, both from Radio Shack.
Posted on Mar 08, 2008
  • 88 Answers
Mine is missing the component, can i get another? What is it? HELP!?!
Posted on Mar 15, 2008
    Problem Solver:
  • 13 Answers
Now you must send the unit to nintendo for a service repair
Posted on Dec 27, 2007
Ok i have a nintendo ds lite and when i turn it on the green light turns on but not the screens on top and bottom
Assuming there is no water damage to the DS lite the most likely causes for this is that you have most likely either dislodged the wifi module, or the L2 component has come off the motherboard.
I would suggest sending it off if you have a warranty, take it to a repair shop if your warranty has expired or if you fancy repairing it yourself then you wil need to dismantle the DS lite.
If its the wifi module that has come loose then its just a matter of pushing it back into place. If its the L2 component it will need to be soldered back onto the board.
Hope this helps,
Regards,
SOD69
Mar 13, 2010 | Nintendo DS Lite Console
Ds lite got dropped now not working it turns on but nothing on the screens ,,screens look ok help
You have most likely either dislodged the wifi module or the L2 component has come off the motherboard.
Hope this helps,
Regards,
SOD69
Feb 24, 2010 | Nintendo DS Lite Console
My Nintendo DS LIte wont turn on!!
Are there NO LIGHTS at all ? Check continuity of F1 and F2 and make sure that L2 (by the ON/OFF switch) hasn't been dislodged. At the very worst you can buy a new motherboard for about £38.00 (~$60 UK).
Sep 19, 2009 | Nintendo DS Lite Console
Ds lite battery wont charge i have charged it overnight but nothing the green light goes on but that is it
If the green light is turning on and the screens are staying blank it is a problem with he L2 fuse on the motherboard (located just below the power button).
This can be replaced if you are handy with a soldering iron. If not drop it to a local repair shop it can be fixed for about €20.
Aug 26, 2009 | Nintendo DS Lite Console
Nintendo ds won't turn on
Many times, it is the L2 Inductor chip that has popped off on impact- that's usually what you hear rattling around inside the housing...and it requires a TriWing screwdriver to open it. I tried re-soldering the L2 inductor back on the mainboard inside with a Hakko ESD protective soldering station, and it worked for a few days and then died again. The fix was finally desoldering another SMD inductor chip off an old PIII Socket 370 motherboard (with ChipQuik removal solder and flux kit) of very close to the same size class, from next to the Clock Generator Chip- figured it would be close to the right value, since I had no way to measure the micro- or millihenries value, and the voltage was around the value that the DS Lite runs on. The fix worked, and is still working, charging, and going strong. Usually the symptoms of the L2 inductor popping off, or failing, is being able to charge, but not being able to power up.
Mar 17, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Problem
That sounds like your DS lite have a lose circuit part rolling inside so thats why it cant turn on.
You need to open the console, recover the lose part from the inside and resolder it in its place (usually near the power switch, marked as L2). That should fix the problem, if not then you might have blown fuses, lose screens ribbon cables or broken LCD screens. All of these repairs are discussed in other questions here.
Regards
Nov 08, 2008 | Nintendo DS Lite Console
Ds Lite not power up L2 Inductor is not good not work.
For the L2 L4 inductor specification, I check the following website, on there have original L2,l4 inductor power and specification
http://www.logictoyz.com/nintendo-ds/nintendo-ds-lite-spare-parts/ds-lite-l2-inductor-power-replacement-.html
By the way,L2,L4 is not fuse,
It is Inductor power
May 30, 2008 | Nintendo DS Lite Console
Dropped Nintendo DS Lite
This part probably broke off.
Dec 09, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
1,168 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
