Question about ViewSonic N3251w 32 in. LCD HDTV
Flashing i have the n3251w and recently it start flashing and u can only watch it for about 10 minutes at a time. i dont know whats wrong with it.
Check the transformer at the top left of the power supply. If it squeaks real loud or buzzing, it will need to be removed and replaced.
Posted on Jul 08, 2008
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Lights flashing
Replace the lamp. The lights flashing will also indicate what is wrong. Watch how they flash. Go to the manufacturers website and they way they are flashing indicates what is wrong (ex. 3 quick flashes, long continuous flashes...etc.) When you change the lamp reset the lamp counter in the menu and clean or replace the dust filters as well.
Jan 11, 2014 | Sanyo PLC-XP200L Projector
2001 monty carlo changed battery securty light flashing car wont start. car ran great before any trick or code i dont know to get it to start
Leave the key in the run position until the security light stops blinking. This should take 10 minutes. Then turn the key off, wait 5 seconds and try to start it. The security light should be blinking again. Leave the key on again for 10 minutes. Repeat this 3 times. After the third time on the the next start it should start and run fine. This will reprogram your theft system.
Feb 06, 2011 | 2001 Chevrolet Monte Carlo
Need instructions to set the auto to brew. I know how to set the brew time, just don't know how to get it to run auto at that time. What am I doing wrong?
Press and hold the program button till the time flashes. Set the hour and minutes by pressing the hour/minute buttons. After you have the correct start time it will automatically go back to time after a while (may be able to press program again to finish set, don't remember). Press program to turn it on (greeen lite will come on to show it is set).
Oct 24, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Phantom on/off
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
I repair these power supplies, if you need further assistance let me know where to contact you.
Aug 11, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Casio 4305 battery change problem
You don't say whether it has the minutes right and the hour wrong or if both are wrong. If it's just that the hour is wrong, you need to set the time zone.
Atomic clocks and watches have a "zero" position. Your manual should tell you how to "zero" the watch and what the time should be when it is zeroed. Each manufacturer is different. I have one that points to 3:00 and one that points to 12:00. If you zero your watch and it doesn't point to the right position, you will need to remove the movement from the case and manually move the hands to the zero position.
Been there, done that.
Jun 13, 2009 | Casio Waveceptor Atomic VQ200HA 1AV watch
Service engine soon
You have to time this perfectly or else it won't work.
Turn ignition switch on, after 3 seconds pump gas pedal five times. Once 15 seconds has passed hold pedal down for more than 10 seconds. The code will start to flash via the check engine light. Take your foot off the pedal. Watch it for a while, it will continue to flash the codes in a loop. To clear, hold the pedal down for more than ten seconds.
Oct 18, 2008 | 2004 Nissan Altima
Digital settings
Buttons are: A or Adjust (10 o’clock position), B or Time Memo (2 o’clock), C or Mode (8 o’clock), D or Receive (4 o’clock) and L or Light (6 o’clock)
To manually change time, date, year, month and day, hold A until beep and city code appears; press A again until 12H/24H flashes; press C to cycle through options as hour, minutes, year, month, and day flash; use B or D to change flashing option.
Aug 03, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start again to turn it on
May 15, 2008 | Watches
ViewSonic N3251w 32 in. LCD HDTV Logo
85 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
