Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
HDMI Monster cables
Will a 1080p HDMI cable work on a 1080i televison. i connected a PS3 to my 1080i sony tv but i have no picture. i noticed on the monster HDMI packaging that it's a 1080p cable, and my tv is 1080i
  • rwaldo Dec 27, 2007
    I´ve connected a ps3 hdmi cable to my sony KP wt520, and there´s no image
I had the same issue. I think you have to reset your PS3. I don't remember how I fixed it but I did find the anwser in the PS3 user manual "Trouble Shooting".
Posted on May 19, 2008
Ps3 only displays in 1080i
I have similar problem , ps3 320gb + 5 years old sony bravia 1080p = everything OK
but when i connect ps3 to new samsung ue46d7000 1080p = doesn't work (only 1080i)
I am using same HDMI cable
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
My playstation 3 will not play in 1080p. It used to work, but when we switched cables, it wont work in HD.
When you switched cables, you mean you changed the cord running from the PS3 to the TV? HD content requires an HDMI connection from the PS3 to the TV. It is possible that when you changed cables, you replaced the PS3's HDMI cable with Component Cables which can only deliver in Standard Definition and not in High Definition (720p, 1080i and 1080p).
Apr 29, 2011 | Sony Playstation 3 (PS3) Console
I have audio but no video with my HDMI connection
You may have the resolution on the PS3 set higher (say 1080p) then what your TV supports (1080i or 720p). Use the Yellow/Red/White cable that came with the PS3 to connect to the TV. Go to that input and check the resolution. Start at a lower resolution and check the HDMI input. If the TV does support 1080p, try a different/better HDMI cable.
Apr 05, 2011 | Sony Playstation 3 (PS3) Console
My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Aug 14, 2009 | Sharp LC19DV22U 19 in. LCD Television
Cannot output 1080p with a full hd 1080p hdtv
In the settings menu, go to video settings. You can have the PS3 search for "optimal settings" This will tackle both video & audio.
On a side note, you didn't need to spend all that money a HDMI cable. ( I'll bet it's a 'Monster' cable, right? ) The $16 Phillips at walmart is just as good. Unless your doing "broadcast quality digital" work, the expensive cables are overkill. Sorry, bro.
May 18, 2009 | Sony Playstation 3 (PS3) Console
PS3 static on screen
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
May 14, 2009 | Sony PlayStation® 3 (80GB) Console
Playstation 3 Flickers when set to 1080P
It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
Oct 02, 2008 | Sony Playstation 3 (PS3) Console
Ps3 reset
turn the PS3 off. hold the power button for at least 5 seconds or until you hear another beep.
This should reset all your ps3's settings.  If you have an HDMI connection, wait for a couple of seconds so that the PS3 recognizes and negotiates the right video output for your TV.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
226 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
