Question about Ricoh Aficio CL2000N Laser Printer
:Load Papers" Whenever Print command is clicked, panel says "Load Papers" It used work without this process. I have to press form feed and enter to make the printer work.
  • Anonymous Mar 16, 2014
    load paper or form feed
  • 417 Answers
Hi there this should be a simple one there are three suggestions the first one if you goto word or which ever program you are using goto file then select page setup once in there check the paper size is correct to the paper that is in the machine and check that paper source is from tray (Cassette) I trust this is the only printer on your system if not you must select this printer before you start the above.
The second on is in the properties of the printer goto start printers and faxes the right hand click on the printer and select printing preferences. Once in there check that you are set for the cassette for paper feed and the print size is set to same as original.
The third one is on the machine itself go into the menu and select paper handling and set the cassette to be used first and make sure it is set to the correct size paper as well.
The most common one would be the first one as not many people change the settings within the driver or the machine.
Hope this is some help to you
Thanks J
Posted on Jan 02, 2008
If you are using regular letter size continuous printer paper, load the paper normally with the machine turned off. You can even turn the knob to feed the paper through, it doesn't matter how far. Turn the printer back on and press "PARK" button. Then press the "FF/LOAD" button and when you begin printing it will automatically print at the top of form (TOF). If the TOF ever gets thrown off you can press "LINE FEED" until the tear is where you want it and press "SHIFT" > "TOF" to back back to the previous page (or top of form).
Simply put, pressing "PARK" then "LOAD" should set the tear where you need it.
May 20, 2011 | OKI MICROLINE 490 Matrix Printer
"Load paper"
hey not a big problem. its usually encountered by many users.
i too get this many times.
this happens when you keep papers freshly.
it needs to sense the papers kept.
now what you do is just keep more papers or try re-aligning the papers kept inside
Dec 27, 2007 | Ricoh Aficio CL2000N Laser Printer
Put new roll in printer and paper feeds through then goes back out again
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
How do one correct print quality in hp color laser jet 2600n
Hi Good day!!
Follow this method hope it helps you!!
During the printing process, paper, toner and dust particles can accumulate inside the printer. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This printer has a cleaning mode that can correct and prevent these types of problems.
This printer has two processes for generating cleaning pages: one is automatically generated and one is manually generated. When a new black print cartridge is installed, a cleaning page will be automatically generated prior to calibration.
Clean the fuser using HP Toolbox
NOTE: Use the following procedure to clean the fuser using the HP Toolbox. To clean the engine when the computer is running an operating system that does not support HP Toolbox, see the late-breaking Readme on the root of the CD-ROM, or visit .
1 Make sure that the printer is turned on and in the Ready state.
2 Open the HP Toolbox using one of the following methods.
On the Windows desktop, double-click the HP Toolbox icon.
* On the Windows Start menu, click Programs (All Programs in Windows XP), click HP , click HP Color LaserJet 2600n, and then click HP Color LaserJet 2600n Toolbox .
3 Click the Troubleshooting tab, and then Troubleshooting Tools .
4 Click the Print button next to step 1, "Click the "Print" button to print out the Cleaning Page."
5 Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1.
6 Click the Clean button to complete the cleaning process. Press the GO button on the printer control panel. The Cleaning page will print, with a second page adhered to the first page. This is normal behavior during the cleaning process.
Cleaning spilled toner
Defective print cartridges can develop leaks. Also, after a paper jam has occurred, some toner might remain on the rollers and guides inside the printer. The pages that print immediately after the jam can pick up this toner.
CAUTION: When cleaning the printer, do not touch the ETB with a damp cloth or with fingers.
Cleaning the paper path
The device features a special cleaning mode to clean the paper path.
NOTE: If there is access to HP Toolbox, HP recommends cleaning the paper path by using HP Toolbox.
Clean the paper path
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press (SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Cleaning Mode, and then press (SELECT).
A page feeds through the printer slowly. Discard the page when the process is completed.
3. Load plain letter or A4 paper when prompted.
4. Press (SELECT) again to confirm and begin the cleaning process.
Calibrating the printer
Calibrations are performed at regular intervals. For best print quality, a calibration can be performed from the control panel using the following steps:
NOTE: This will calibrate the color and clean the black electrostatic transfer belt (ETB).
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select System setup and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Print quality and then press (SELECT). Calibrate color will display on the control panel.
Press (SELECT).
3 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Calibrate now and then press (SELECT).
4 Press (SELECT) to start the calibration.
Other options for print quality defects that still persist
Oct 26, 2010 | HP Color LaserJet 2600n Printer
I can't clear cancel a document waiting to print
In Windows, if cancelling the print job does not work, the command prompt can be a very useful tool. Go Start button, All Programs, Accessories, Command Prompt (if standard user, right click and run as administrator) (These are for Vista and Win7, XP is similar and older were similar)
Type "net stop spooler" without the quotes and hit enter. When a new prompt appears, type "net start spooler" (again without the quotes and hit enter). You can also do these one line at a time: Start Run and the two phrases. Once the commands have executed restart the computer.
If you only type the first line and then reboot, plan on taking a coffee break before the command finishes processing on the restart.
I hope this helps.
Feb 27, 2010 | HP Office Equipment & Supplies
Says its printing but it wont print
Open up your print queue. Cancel All jobs.
Go to the start menu and either click on, or search for cmd. This will open the command window. You also need to open your task manager.
In the task manager, search for a process called spoolsv.exe, or if that doesn't exist, find a process with "spool" in the name. This is your print spooling process. Right click the process, and end it. You can close the task manager now.
Next, go to the command prompt. Type "net start spooler" without the quotes, and hit enter. This should restart your spooling process. Close the command window, and try to print.
If this doesn't work, you should check to make sure you're printing to the correct printer. If it doesnt solve the problem, uninstall your current printer (you may have to end the spoolsv.exe process again), and reinstall the drivers for your particular model, which you can find at the manufacturers website.
Jun 22, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Line feeds
When you said line feed do you mean the Top of form?
hope this helps
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
Keep me posted if you have inquiries, thanks!
Jun 18, 2008 | Epson DFX-9000 Matrix Printer
Documax 3300 printing problem
Start by running a test print from the control panel - with paper loaded, open the panel, press the "feature up" button - the display will say "run self test" and press enter - you should get a "barberpole" test print.
If the paper feeds properly in the self test, your problem lies in the print command, you need to send the appropriate LF character to tell the printer to feed the paper to the next line. You can also enable auto LF in the profile you are using, but this would not be my first choice.
May 20, 2008 | AMT Datasouth Datasouth Documax 3300...
Spooler serivice is stopped
This article describes two methods for restarting the Print Spooler service within Vista.
Method 1: Restart the service using the services console
  1. Click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. If you are prompted for an administrator password or for confirmation, you can either type your password or click Continue.
  2. Right-click Print Spooler, and then click Stop.
  3. Right-click Print Spooler again, and click Start.
Method 2: Restart the service at a command prompt
  1. Click Start, All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
  3. Type the following commands at the command prompt.
    net stop spooler [Press ENTER.]
    net start spooler [Press ENTER.]
    exit [Press ENTER.]
Apr 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Ricoh Aficio CL2000N Laser Printer Logo
131 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
