Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Half of screen is not viewable
For some reason some time ago the bottom half of the screen only has vertical lines. The top half of the screen is perfect. This is a teenagers laptop, but it has not been abused. Any help will be greatly appreciated
  • Anonymous Mar 14, 2014
    horizonal lines bottom half computer screen top half OK
  • 56 Answers
Well the issue is usally with the Video driver.Try reinstalling it from the support.dell.com and that should resolve the issue.Also you can try connectring a external moniter and see if you get the proper display on that or not.Incase you do than issue is with the screen and incase its the same on that as well than its an issue with the video card.You can get either of the two replaced accordingly.
Posted on Dec 27, 2007
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
How do I fix vertical lines and no picture.
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
My screen went black
If the bottom is black it's the lower buffer board and I believe that's the Y buffer board. Should have on ebay fairly inexpensive
Aug 11, 2014 | Philips 50PF9631D 50 in. HD-Ready Plasma...
The top half of the screen is at the bottom...and the bottom half is at the top of the screen...theres a black line through the middle...why is this happening please...
The fault is with its vertical scan output stage circuit. Contact any service technician. This is not a user reparable fault. [Out of Sync: picture].
Gopakumar Gopalan Google
Feb 11, 2014 | Proton MM2701VT 27" TV
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
I see 11 flashing groups of about 4 ununiformely-doted lines (black and white) on my screen. Ech group of 4 lines is separated from the next by about the same width of the group (i.e. the screen is divided...
there maybe some problem with the vertical circuits with your tv, if you are still satisfy and tv is viewable then patiencely watch it. however as times goes by using it, if the defect is not corrected it may worsening the vertical circuits problem. scanning vertical trace is the problem of your tv.
Feb 06, 2011 | Pioneer PDP-4271HD 42 in. Plasma...
I have a 20ms3442/17 the screen only shows the bottom half of the picture and the upper half is lines and a reverse image on the first half of the top of the lower half
You have a vertical foldover. Check the caps near the two vertical ICs. HMMM it does not surprise me...There could be a couple of suface mout caps. to check...I do not remember the locations at this time. But try the electrolytics...they are easy to check.
Nov 29, 2009 | Philips Magnavox 20MS3442 20" TV
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Half a screen
The picture on your TV screen is driven from the center to the top and bottom of the screen by the vertical drive circuit. The fact that you can see the entire picture means you have a problem called foldover. This is caused by a failure in the vertical drive circuit where the vertical saw signal is altered by a component failure within the vertical drive circuit. You cannot solve this problem but any good repair shop should be able to correct the problem at a reasonable cost.
Jun 22, 2006 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
111 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
