Hi my external hard drive (maxtor one touch 4 mini 250gb) is beeping and my computer won't recognise it when i plug either USB in. What can i do to fix this?
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USBextension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpoweredUSB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Maxtor OneTouch 4 Mini 160GB
The mybook software slows down my computer how can I fix that with out having to change it's...
(More)
The mybook software slows down my computer how can I fix that with out having to change it's priority in task manager everytime i restart my computer?
My Book external hard drive doesn't eject. I ejected the first icon, but when I tried to eject the...
(More)
My Book external hard drive doesn't eject. I ejected the first icon, but when I tried to eject the second one (WD SmartWare), it show up again on the desktop. Is that normal? What can I do? Should I just disconnect the USB cable from the computer?
