Question about Compaq Evo T20 Network Terminal
Connection Problems It worked fine before then one day it started doing this. When trying to connect to a terminal server I get this error Terminal services client disconnected The terminal server ended the connection or a network error occurred. Please try to reconnect.
  • theups Jan 08, 2008
    The accounts are fine. I have not had a chance to review the logs. I'll try an do that some time today.
    They don't even connect to the TS. When you frist power on the thinclient and hit connect is when I'm getting this error.
    I was thinking maybe conection issue but I am able to ping the clients.
    Novelist:
    Scholar:
  • 117 Answers
W2000 Terminal Server used to corrupt the accounts of RDP users every now & again. Wouldn't surprise me if W2003 did the same thing :{ I used to create a copy of the user's account on the server (with an incrementing number on the end of the account name) & change the default account in TS management to that new one when this sort of problem occurred. I then made a copy of the new account & deleted the corrupt one.
Of course there are all sorts of other reasons this may happen but that may take a fair bit of hands-on investigation to sort.
For info on what's actually happening: Have you looked in the TS logs? Or the System and Application logs? Have you looked ta the logs in the client? Can you connect to the same TS server & account using a PC & the MS RDP client? If not, try the solution above :)
Posted on Jan 06, 2008
  • Dave Harris
    Dave Harris Jan 08, 2008
    OK - let me know how you get on - I'm intrigued now :)
    One thing that might help (& in any case removes it from the list of possible causes) is to do a netsh TCP/IP reset (if you haven't done this before: you'll have to re-input the IP addy etc for the NIC afterwards).
How do i connect this terminal to windows 2003 server please give me the settings
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Thankyou
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
May 05, 2010 | VXL Instruments Itona CE Windows CE VIA...
Power brakes won't work
was the car sitting for a while?The booster may be at fault.Caliper sticking?Fuses have nothing to do with your problem.It is a brake line problem.Could be a few different small problems.Easy to fix though.Hope this helps you
Nov 18, 2009 | 1999 Jeep Grand Cherokee
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
I have Wyse V50L termimals that cannot connect to Terminal Server 2008. Connections from XP Remote Desktop Client work fine. The server is configured to not use Network Level Authentication. The...
Have you tried the latest V50L firmware version? There was a major revision lately?
http://www.wyse.com/serviceandsupport/support/downloads.asp
Oct 25, 2008 | WYSE Computers & Internet
Conection to Microsoft Windows 2003 server terminal server
G key reset the unit, or failing that, re-image the device, and then setup your RDP connection from the default desktop.
Jul 09, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Terminal server not responding
Are you receiving errors in the "event viewer"? And if you are what are they?
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 20, 2007 | Computers & Internet
The whole OS is gone
hi brtsch Your problems means there is nothing wrong with ur terminal. your terminal server is not starting try booting with last known good conf by pressing F8 option if it dosent work then try with safemode and uninstall what u have install pls mention which server ur using and OS and also if any error codes
Sep 04, 2007 | Neoware Systems c50 Thin Client Network...
Compaq Evo T20 Network Terminal Logo
413 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
