-goto LAN devices, click properties on yourLAN, scroll down and select Internet Protocol (TCP/IP), clickproperties, click set and type follow IP address:
first of all, you don't want to have the http stuff in the address bar. Just type the ip address, 192.168.0.50 . some others that might work are 192.168.0.1 and 192.168.1.1
at computer start up, get messages #1 air gcfg.exe-entry point could not be found #2...
(More)
at computer start up, get messages #1 air gcfg.exe-entry point could not be found #2 wzcsldr2.exe-entry point could be found
I have solution 1. start -> run 2. type regedit to open registry 3. go to...
(More)
I have solution 1. start -> run 2. type regedit to open registry 3. go to HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerMountPoint2 4 now you can see keys like {4bdd4abb-fe4b-11d5-8453-806d6172696f} {4bdd4abe-fe4b-11d5-8453-806d6172696f} 5. if you see any sub folder in it like Shell 6. delete Shell folder 7. now open windows explorer and double click on your d or e drive 8. enjoy... Do it at your own risk.....
Hi! I need to know were the fusils are located, the lamps are not working and I don't have the...
(More)
Hi! I need to know were the fusils are located, the lamps are not working and I don't have the manual book. Thanks
